[Announce] OCL goes Generic! And OCL goes UML! [message #1204] |
Tue, 30 January 2007 00:45 |
Hi, all,
The latest integration build of OCL:
http://www.eclipse.org/modeling/mdt/downloads/index.php?proj ect=ocl
is a big change over OCL 1.1 M4. This build includes the following
enhancements:
- adopt EMF 2.3/J2SE 5.0
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156361
- Support OCL expressions on the UML Metamodel
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163808
in addition to numerous bug fixes.
The following new features (in Update Manager terms) are available:
- org.eclipse.ocl: a refactoring of the org.eclipse.emf.ocl feature,
including a generic OCL Abstract Syntax model (using Ecore generics)
and an Environment implementation for Ecore. This feature includes
the org.eclipse.ocl and org.eclipse.ocl.ecore plug-ins that replace
the org.eclipse.emf.ocl plug-in
- org.eclipse.ocl.uml: a new Environment implementation for the UML
metamodel. This implements support for parsing OCL constraints and
queries on UML models (as opposed to Ecore models)
The org.eclipse.emf.ocl feature continues to be supported, with all of the
M4 and earlier API. This API is now deprecated, as it is hard-wired to the
Ecore metamodel and is obsoleted by the new generic parser. I encourage
you to migrate to the new org.eclipse.ocl API as you are able. The
Interactive OCL Console (org.eclipse.emf.ocl.examples.interpreter) example
plug-in is updated, so it should help to demonstrate; likewise the
org.eclipse.ocl.ecore.tests. A more complete migration guide will be
forthcoming.
Christian
Re: [Announce] OCL goes Generic! And OCL goes UML! [message #3727 is a reply to message #1204] |
Wed, 07 February 2007 20:16 |
Originally posted by: chaves.inf.ufsc.nospam.br
This is great news! I work with UML2 and when I learned that Eclipse OCL
support was geared towards EMF only it was a big turnoff. I just
downloaded the latest integration with suport to UML2 and will start
looking into using it right away.
Keep up the good work!
Rafael
Christian W. Damus wrote:
> Hi, all,
> enhancements:
> forthcoming.
> Cheers,
> Christian
FUDForum. Page generated in 0.21932 seconds
