Connection behind node [message #155318] |
Sat, 23 October 2004 21:33 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: meowmeow64.yahoo.co.kr
I searched archive regarding how to make connection appear behind node.
There is bunch of bits and piece informaions.
is there definite guide on this? what is best approach?
I am trying to modify code on emf-gef tutorial example.
Any input would be appreciated.
Re: Connection behind node [message #155416 is a reply to message #155318] |
Mon, 25 October 2004 03:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I don't understand you objective. Connections go between 2 nodes, not
behind them. Are you talking about z-order?
"john Lee" <meowmeow64@yahoo.co.kr> wrote in message
news:cleint$c9s$1@eclipse.org...
Re: Connection behind node [message #155597 is a reply to message #155416] |
Tue, 26 October 2004 08:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Sorry Randy, I should have been more clear.
like layers again post, I want the connections _not_ to be layered on
top of my nodes, but want them behind them
Manhattan router works great for my project. The one problem is that when
I make a lot of connection between nodes, figures get covered with
connection lines. I wish figure can hide any connection which intersects
with figure.
is layers again post method best approach?
According to layers again post,
1. In FreeformGraphicalRootEditPart#createFigure() the layers are added,
changing the order if adding (e.g. adding the connection layer first in
a subclass)
2. make all layers transparent and editpart figures transparent.
3. in order for targetting work,
subclassed FreeformLayer for edit part figure and overwrirte the methods
findFigureAtExcluding and containsPoint.
is this right approach?
Thanks for your help and your wonderful project.
Re: Connection behind node [message #155649 is a reply to message #155597] |
Tue, 26 October 2004 14:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
That solution is probably workable. However, if connections go under a
node, how can the user visually tell the difference between a connection
which stops AT a node, vs. a connection which looks like it stops at a node,
but actually goes UNDER the node?
If you look at ShortestPathConnectionRouter in our latest builds, you will
find a router where connections never cross over nodes. If you avoid the
problem, you don't have to change the order.
news:cll0o2$ltg$1@eclipse.org...
> with figure.
> a subclass)
node.
Re: Connection behind node [message #155763 is a reply to message #155649] |
Tue, 26 October 2004 17:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks for response.
I have input node and output node. I visually indicated with arrow showing
inputs and outputs. However, I am afraid I might run into other issues
with this approach since gef seems not designed for this kind of approach.
is there a way to provide bended straight line with
ShortestPathConnectionRouter like Manhattan router provides?
Again, thank you very much for your time and response
Re: Connection behind node [message #155770 is a reply to message #155763] |
Tue, 26 October 2004 17:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
news:cllvr5$u98$1@eclipse.org...
node,
Not sure what you mean there. Certainly we support arrows on the ends of
connections.
will
the
A shortest-orthogonal-path router or algorithm does not exist in GEF.
FUDForum. Page generated in 0.03982 seconds
