create a node and a link programmatically [message #155266] |
Mon, 15 October 2007 11:02 |
Originally posted by: bmoros.um.es
Hi all,
In the "Custom Action", in the third part of the GMF tutorial
(http://wiki.eclipse.org/GMF_Tutorial_Part_3#Custom_Actions), a new Subtopic
node and a new Link (from the selected Topic to the new Subtopic) are
created. Following the example, I have been trying to do the same thing with
no success. In my case, the node is created but the link is not.
I also have tryed to create the link by means of
CreateViewAndElementRequest.getCreateCommand. In this case, the link is
graphically shown but the model lement is not created.
I do not know what other command or approach I can use.
I have been stuck on this stuff for some weeks, please, can anybody help
me??
Bego
Re: create a node and a link programmatically [message #155315 is a reply to message #155266] |
Mon, 15 October 2007 11:59 |
Originally posted by: trommas.yahoo.com
We are in the same boat Begoña :) I have also been working on this for a
few weeks.
I successfully create node and link, the part that creates the link
looks like this in my case:
IElementType linkType = UemlbaseElementTypes.Class_SubclassRelation_4001;
CreateConnectionViewAndElementRequest connectionRequest = new
CreateConnectionViewAndElementRequest( linkType, ((IHintedType)
linkType).getSemanticHint(), selectedElement.getDiagramPreferencesHint());
ICommand createSubClassLinkCmd = new
DeferredCreateConnectionViewAndElementCommand(connectionRequ est,
shapeViewAdapter, new EObjectAdapter((EObject)
selectedElement.getModel()), selectedElement.getViewer());
Does this help?
If any one else is reading this, I really need help in "catching" the
newly created link/connection object.
Tomas
Begoña Moros wrote:
> Hi all,
> me??
> Best regards,
> Begoña
Re: create a node and a link programmatically [message #155400 is a reply to message #155315] |
Mon, 15 October 2007 14:58 |
Tomas, I do not understand!! My code is the same as yours (you can look at
it below). First, I create a new node (ProductRequirement in my case) and
then the link (DependenceTrace) between the current element, that is the
current ProductRequirement (my code is in the
ProductRequirementEditPart#handleNotificationEvent method) and the new
ProductRequirement. The only thing different is that I use "this" (to refer
to the current ProductRequirement) instead of "selectedElement".
What is the type of selecteElement in your case?
CompoundCommand commands = new CompoundCommand();
// types to be
reated --------------------------------------------------------
IElementType nodeType = ParamMMElementTypes.ProductRequirement_1001;
IElementType traceType = ParamMMElementTypes.DependenceTrace_3001;
// create the node --------------------------------------------------------
CreateViewRequest nodeRequest =
CreateViewRequestFactory.getCreateShapeRequest(
nodeType,
this.getDiagramPreferencesHint());
commands.add(catalogEditPart.getCommand(nodeRequest));
// create the trace --------------------------------------------------------
CreateConnectionViewAndElementRequest createTraceRequest = new
traceType,
((IHintedType)
traceType).getSemanticHint(),
// Source of the link: this, the current element
IAdaptable sourceViewAdapter = new EObjectAdapter((EObject)
this.getModel());
//Target of the link: the new created Requirement
IAdaptable targetViewAdapter = (IAdaptable) ((List)
nodeRequest.getNewObject()).get(0);
ICommand createTraceCmd = new DeferredCreateConnectionViewAndElementCommand(
createTraceRequest,
sourceViewAdapter,
targetViewAdapter,
this.getViewer());
commands.add(new ICommandProxy(createTraceCmd));
this.getDiagramEditDomain().getDiagramCommandStack().execute (commands);
"Tomas Zijdemans" <trommas@yahoo.com> escribi
Re: create a node and a link programmatically [message #155476 is a reply to message #155423] |
Mon, 15 October 2007 19:37 |
No, I have not done anything with the EditPolicies.
Tomas
Begoña Moros wrote:
> Did you have to install any EditPolicy in the XXXEditPart in order to create
> the link by CreateConnectionViewAndElementRequest properly?
> "Tomas Zijdemans" <trommas@yahoo.com> escribió en el mensaje
> news:ff01ej$gmn$1@build.eclipse.org...
>> It is ClassNodeEditPart.
>> I have to go now, but I'll be able to assist tomorrow. You can just email
>> me if you want
>> Regards,
>> Tomas
Re: create a node and a link programmatically [message #155508 is a reply to message #155423] |
Tue, 16 October 2007 07:06 |
Maybe you could send me your code?
I will compare it to mine, and see if I can solve your problem.
Tomas
>> me if you want
>> Regards,
>> Tomas
Re: create a node and a link programmatically [message #155574 is a reply to message #155508] |
Tue, 16 October 2007 10:39 |
Tomas thank you very much for your time!!
My code is part of the handleNotificationEvent in ProductRequirementEditPart
class. What I want to do is create a new ProductRequirement (my node) and
link it (by means of a TraceDependence) to the current ProductRequirement
(the one that has changed some way).
My code is as follows:
IElementType reqType = ParamMMElementTypes.ProductRequirement_1001;
// create the node. This
works!! --------------------------------------------------------
CreateViewRequest reqRequest =
reqType,
commands.add(catalogEditPart.getCommand(reqRequest));
// create the trace. Nothing
happens!!! --------------------------------------------------------
traceType,
((IHintedType) traceType).getSemanticHint(),
this.getModel());
reqRequest.getNewObject()).get(0);
createTraceRequest,
sourceViewAdapter,
targetViewAdapter,
this.getViewer());
Bego
Re: create a node and a link programmatically [message #155700 is a reply to message #155574] |
Tue, 16 October 2007 11:28 |
No prob :) Our codes are quite different, but here is what I think your
code should look like:
private ProductRequirementEditPart selectedElement;
public void run(IAction action) {
reqType,
// Get the Adapter to the newly created object
shapeViewAdapter = (IAdaptable) ((List) reqRequest.getNewObject()).get(0);
selectedElement.getDiagramEditDomain().getDiagramCommandStac k().execute(cc);
traceType,
((IHintedType)
createTraceRequest, shapeViewAdapternew EObjectAdapter((EObject)
// Setup link compound command
CompoundCommand cc2 = new CompoundCommand("Create connection");
cc2.add(new ICommandProxy(createTraceCmd));
selectedElement.getDiagramEditDomain().getDiagramCommandStac k().execute(cc2);
public void selectionChanged(IAction action, ISelection selection) {
selectedElement = null;
if (selection instanceof IStructuredSelection) { IStructuredSelection
structuredSelection = (IStructuredSelection) selection;
if (structuredSelection.getFirstElement() instanceof
ProductRequirementEditPart) {
selectedElement = (ProductRequirementEditPart)
structuredSelection.getFirstElement();
Puh! I think that should work. I may be traveling to Spain (that is
where you come from, right?) this spring to collect data for my master
thesis. Looking forward to it (Norway is cold!)
Hope this helps,
Toams
FUDForum. Page generated in 0.04104 seconds
