Home » Archived » BIRT » charting problem
charting problem [message #155241] |
Fri, 21 April 2006 13:53 |
imre farkas Messages: 26 Registered: July 2009 |
Junior Member |
I have a question about charting:
I have a csv datasource:
Type,Amount,Currency
STRING,DOUBLE,STRING
A,10000,EUR
B,500,EUR
C,400,USD
A,300,USD
C,800,EUR
B,600,EUR
I create a table with groupping by Type (type is the first column) and
the second column is Total.sum(row["amount"], row["Currency"] == "EUR")
and I have not got details row.
The result is fine:
Type EUR
A 10000
B 1100
C 800
I want to create a pie chart where the slices are A, B and C and values
are A = 10000, B = 1100, C = 800 but I have not been able to do this.
It maybe not possible in birt...
thx in advance
-farkas
ps: I currently use Birt 2.0.1
Re: charting problem [message #155459 is a reply to message #155241] |
Sat, 22 April 2006 07:17 |
David Michonneau Messages: 1145 Registered: July 2009 |
You can set a filter on the chart to filter out the USD values. Then you can
group in the chart by Type (category Series/Group, choose Text, interval set
to 0, aggregate=sum). This should work
David
"farkas" <farkas.imre@chello.hu> wrote in message
news:e2ao46$jmd$1@utils.eclipse.org...
> A,10000,EUR
> B,500,EUR
> C,400,USD
> A,300,USD
> C,800,EUR
> B,600,EUR
> I create a table with groupping by Type (type is the first column) and the
> second column is Total.sum(row["amount"], row["Currency"] == "EUR") and I
> The result is fine:
> Type EUR
> A 10000
> B 1100
> C 800
> thx in advance
> -farkas
Re: charting problem [message #155471 is a reply to message #155459] |
Sat, 22 April 2006 15:22 |
Junior Member |
David Michonneau írta:
> David
>> A,10000,EUR
>> B,500,EUR
>> C,400,USD
>> A,300,USD
>> C,800,EUR
>> B,600,EUR
>> The result is fine:
>> Type EUR
>> A 10000
>> B 1100
>> C 800
>> thx in advance
>> -farkas
thanks a lot. it works. great.
regards
-farkas
Current Time: Tue Jul 23 09:05:35 GMT 2024
Powered by FUDForum. Page generated in 0.02814 seconds
