Home » Language IDEs » C / C++ IDE (CDT) » Building Make Target
Building Make Target [message #155145] Tue, 27 September 2005 13:09 Go to next message
Originally posted by: andrmeyer.gmx.de
I'm using the "Standard Make C++ Project" option with Eclipse 3.1 and CDT.
My problem is that I want to compile just one program from a project.
("make program_x" from the command line). I discovered the following
possibilities so far:
- "Create Make Target" and use "Build Make Target" every time. This isn't
optimal since I can't use hotkeys to build.
- change target "all" in my Makefile to my program. after this I can use
"Build All" and the corresponding hotkey. But since I work on a subversion
project I like to leave the makefile unchanged
So, is there any possibility in Eclipse to achieve the second
functionality without changing the Makefile?
best regards,
André
Re: Building Make Target [message #155239 is a reply to message #155145] Wed, 28 September 2005 07:00 Go to previous message
In article <cb7cf226818a797a720feebfe75c2a8f$1@www.eclipse.org>,
andrmeyer@gmx.de says...
> I'm using the "Standard Make C++ Project" option with Eclipse 3.1 and CDT..
> best regards,
> André
Go to the properties of your project and open the "C/C++ Make Project"
page.
On the "Make Builder" sheet you can specify which target the workbench
will (re)build. Enter your target "programm_x" instead of "all".
Best regards
Klaus
Previous Topic:Still cannot exclude directories from manged build
Next Topic:Can create project
Current Time: Wed Apr 16 04:04:14 EDT 2025
Powered by FUDForum. Page generated in 0.24597 seconds
