CDT Console Problem [message #155052] |
Mon, 26 September 2005 14:21 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: rowck001.bigpond.net.au
Running Mingw with CDT on WinXP
CDT works great!! but some issues with the console.
It does not like repeated cout calls
eg. with this simple code from a console-mode app;
cout << "Just going to execute a loop!!" << endl;
for(int i=0; i < 6; i++){
cout << "Iteration: " << i << endl;
all that is output on console is "Just going to .... "
The output from the loop is not shown, but running from a command prompt
shows correct ouptut.
Is this an bug in the console or normal behaviour?
Re: CDT Console Problem [message #155066 is a reply to message #155052] |
Mon, 26 September 2005 17:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Solved my own problem - checked the bugzilla (always helps!)
Quick Solution;
I add a program input wait function, eg. getchar() at the end of the main
function in an application and then execute by double-clicking the exe
from either the debug or release options in the outline and use the dos
box window to view the output
hope this helps
FUDForum. Page generated in 0.04621 seconds
