reconciling the gmfgen [message #154922] |
Fri, 12 October 2007 09:58 |
Originally posted by: Sam.sam.sam
when u create a link with more then one labels you can finetune the label
positioning in the gmfgen. the default setting for every label is 'middle'.
you finetune and for example set the label position to source.
- every time you reconcile the generator model, your finetune gets lost,
every label is set to 'middle' position.
Is it a bug or do i miss something tricky, like adding label positioning the
gmfgraph, or so?
regards
Sam
Re: reconciling the gmfgen [message #154985 is a reply to message #154922] |
Fri, 12 October 2007 10:31 |
Originally posted by: snej_NO-SPAM_.esuark.de
> gmfgraph, or so?
You can add "Alignment Facet" to the "Diagram Label XXX" part in your
..gmfgraph file.
hth
jens
FUDForum. Page generated in 0.03725 seconds
