| Showing only a part of a line series? [message #154915] |
Thu, 20 April 2006 14:53  |
Originally posted by: mikewulkan.flyingmoose.ca
I have a chart with 3 line graph series. Series 1 data is meaningful from
X1-Xa. Series 2 data is meaningful between Xa -Xb; and finally Series 3
data is meaningful between Xa - Xc.
Currently I am just setting the values of the series to 0 where the series
falls outside their meaningful ranges. However this doesn't look very nice.
Is there a way of limiting the X axis range where a line series is actually
plotted?
Mike
| Re: Showing only a part of a line series? [message #155219 is a reply to message #155212] |
Fri, 21 April 2006 09:10  |
Ooops! Nevermind that last post. I was plotting the wrong value.
Mike
"Mike Wulkan" <mikewulkan@flyingmoose.ca> wrote in message
news:e2akmj$58k$1@utils.eclipse.org...
> Hi David,
> Thanks, this seems to cover about 98% of the problem.
> For some reason the Series 1 plot seems to interpret null values as zero
and
> plots them as such. But the other series behave as you describe and don't
> plot the points.
> Can you think of any reason this should be happening?
> Mike
> "David Michonneau" <dmichonneau@actuate.com> wrote in message
> news:e29vfl$f5q$1@utils.eclipse.org...
> > Not really, but you could try to set some null values instead of 0
values.
> > It should not plot them in that case.
> > Thanks,
> > David
> > news:e28lap$pi2$1@utils.eclipse.org...
> > > Hi,
> from
3
> series
> > > nice.
> > > actually
> > > plotted?
> > > Thanks,
> > > Mike
FUDForum. Page generated in 0.29875 seconds
