Home » Archived » BIRT » BIRT RPC
BIRT RPC [message #154907] Thu, 20 April 2006 16:31 Go to next message
Originally posted by: hjm.holos.pt
Hi...
I'm trying to build a RPC using birt, but i'm having some difficulties in
putting all working.
I had downloaded birt-rcp-report-designer-2_0_1.zip but i don't know what
to do with it.
Thanks for your help
Hugo
Re: BIRT RPC [message #155119 is a reply to message #154907] Fri, 21 April 2006 09:36 Go to previous messageGo to next message
Originally posted by: fabien_allanic.yahoo.fr
Hi, I'm not sure to understand what you want to do, but the zip file you
downloaded is a BIRT RCP version, it let you use BIRT without eclipse.
Maybe you need to download birt-runtime-2_0_1.zip
Re: BIRT RPC [message #155168 is a reply to message #155119] Fri, 21 April 2006 10:25 Go to previous message
Hi..
Thanks for your answer.
I want to change the birt interface, mainly adding new report objects and
to restrict the chance to create new data sources and data sets.
Thanjs
Hugo
Previous Topic:Birt Chart generate Exception
Next Topic:how to set a database schema ?
Current Time: Sat Dec 21 13:19:03 GMT 2024
Powered by FUDForum. Page generated in 0.03586 seconds
