Home » Eclipse Projects » Eclipse Platform » Java code formatting
Java code formatting [message #154673] Sun, 09 November 2003 19:40 Go to next message
Eugeny N Dzhurinsky is currently offline Eugeny N DzhurinskyFriend
Hello, can anybody explain
how can i configure code formatter so it will add one or more blank lines
between methods and constructors in the Java source?
Thank you, best regards
Eugene N Dzhurinsky
http://JDevelop.com - dedicated Java-based WEB solutions
Re: Java code formatting [message #154858 is a reply to message #154673] Mon, 10 November 2003 13:25 Go to previous messageGo to next message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Sun, 09 Nov 2003 21:40:21 +0200, Eugeny N Dzhurinsky
This is not possible for now. It will be possible when the new
preference page is ready.
You can follow bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=45039
Olivier
Re: Java code formatting [message #155085 is a reply to message #154858] Mon, 10 November 2003 23:24 Go to previous message
Kevin Duffey is currently offline Kevin DuffeyFriend
In the mean time, you can use the much more advanced Jalopy plugin, also
free, which will do all that and a lot more for you.
"Olivier Thomann" <olivier_thomann@ca.ibm.comNOSPAM> wrote in message
news:uc4vqv4bc8dvusuqubroe3g8p23iig46c7@4ax.com...
Previous Topic:Native IME with Eclipse
Next Topic:Plug-In w/ Custom View development
Current Time: Sat Nov 09 04:06:05 GMT 2024
Powered by FUDForum. Page generated in 0.02120 seconds
