Suggestions for Code Placement? [message #154532] |
Wed, 31 May 2006 05:30 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: sqlpython.sbcglobal.net
May seem elementary for practiced Eclipse users but I would appreciate
examples as to what more experienced Eclipse and Java coders do.
I can of course place all code for a Project in one dir and make that the
Workbench Home.
But If I want to have access to other Classes i.e ClassPath what is a good
procedure (no pun intended) for Making Eclipse and Java aware of my
Project's and other useful Classes I may create? So Eclipse and I won't be
groping in the dark to find Classes I need.
Thank You
Re: Suggestions for Code Placement? [message #154730 is a reply to message #154556] |
Thu, 01 June 2006 05:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nick Veys wrote:
> You can also create multiple source code directories in the project,
> this will allow you to break up your code if desired (something packages
> will usually be sufficient for).
First off..Thanks very much for the reply.
I am a little uneasy using a Compiler other then the JSE2..But I like the
results.
Secondly I am a little unsure regarding your above statement..
I know the package concept works but how can I utilize the multiple source
dir ?
Re: Suggestions for Code Placement? [message #154950 is a reply to message #154946] |
Fri, 02 June 2006 05:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nick Veys wrote:
> If you right-click on your project you can do New -> Source Folder.
Thanks Nick..Missed that as I have been right clicking there to create
classes. This is the kind of good info that only comes with practice which
is why I appreciate the comeback..
Seems simple when your accustom to the interface but with so much going on
in Eclipse .....
Re: Suggestions for Code Placement? [message #155391 is a reply to message #155043] |
Sun, 04 June 2006 02:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Nick Veys wrote:
> It can be especially difficult if you're still getting used to Java in
> general, as well as learning Eclipse,
Your Right...Fortunately as a long time programmer I am coming up to speed
quickly in Java. I find Eclipse though somewhat foreign and it well present
the more difficult learning curve..
You will see me bouncing questions off this List for a while.. ;^)
FUDForum. Page generated in 0.09789 seconds
