Home » Archived » BIRT » Page Breaks on PDF & nested grids
Page Breaks on PDF & nested grids [message #154381] Wed, 19 April 2006 16:30 Go to next message
Originally posted by: huffordkevin.johndeere.com
I'm experiencing a problem with page breaks when the report is rendered in
PDF. This is on BIRT 2.0.1.
It seems that if I place a grid on the report(Grid A), then inside this
grid nest another grid(Grid B). Then if I set Grid B's pageBreakBefore =
Always, the resulting PDF document doesn't contain the page break.
If I put the 2 grids in sequence on the report, and don't nest them then
the page break works as expected.
So my question is, do page breaks only work on top-level components now?
Or is this a bug? The page breaks on nested grids seemed to work ok in
BIRT 1.0.1.
-Kevin
Re: Page Breaks on PDF & nested grids [message #154438 is a reply to message #154381] Wed, 19 April 2006 18:29 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
Member
Yes, in 2.0, page breaks work only on top-level elements and rows.
"Kevin Hufford" <huffordkevin@johndeere.com> wrote in message
news:eab2bcd846ea2f47efa3ea7966db441a$1@www.eclipse.org...
> BIRT 1.0.1.
> -Kevin
Re: Page Breaks on PDF & nested grids [message #154446 is a reply to message #154381] Wed, 19 April 2006 18:30 Go to previous messageGo to next message
Cristian Popescu is currently offline Cristian PopescuFriend
Hi Kevin. It looks like a bug. I had the same problems that's why I am
avoiding the nested grids or grids with tables.
Re: Page Breaks on PDF & nested grids [message #159061 is a reply to message #154438] Mon, 08 May 2006 12:44 Go to previous messageGo to next message
Frédéric Ferrant is currently offline Frédéric FerrantFriend
Member
Will this change, or is this a definitive behaviour?
I have a problem similar to kevin's (see my previous message for a
full description).
Re: Page Breaks on PDF & nested grids - URGENT [message #159744 is a reply to message #154438] Wed, 10 May 2006 08:59 Go to previous message
Member
Will this change in next versions...?
Previous Topic:probleam in image in html
Next Topic:prob html(image)
Current Time: Thu Dec 26 13:47:01 GMT 2024
Powered by FUDForum. Page generated in 0.04645 seconds
