Draw2D export to WMF or SVG [message #154251] |
Fri, 15 October 2004 11:15 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: usenet.jevopi.de
Is it possible to paste a Draw2D figure to the windows clipboard as
vector graphic, i.e. WMF?
Or is it possible to convert or save the figure as SVG or WMF?
For both problems I know solutions using Swing/AWT graphics (WMFWriter
and Batik)? Are there any projects porting these or similar projects to
SWT/Draw2D?
I found one project related to that issue: holongate.org. Is this
plug-in working with the lates Eclipse/GEF versions?
Jens
Re: Draw2D export to WMF or SVG [message #154356 is a reply to message #154251] |
Sun, 17 October 2004 17:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: boris.bokowski.de
I have a solution using native code and non-API methods. It produces EMF,
the successor format of WMF, and it only works when running under Windows.
The code is experimental, but it worked on a number of examples.
I am currently registering a sourceforge project under the name "tritos" to
share my code with others. Win32 experts are welcome to improve on my
current solution!
I'll post the URL as soon as the project is properly registered.
Boris Bokowski
"Jens v. P." <usenet@jevopi.de> wrote:
> Is it possible to paste a Draw2D figure to the windows clipboard as vector
> graphic, i.e. WMF?
FUDForum. Page generated in 0.03683 seconds
