Creating Eclipse projects from the example sources [message #154243] |
Fri, 15 October 2004 05:28 |
Originally posted by: ranjit.notMyId.com
I wanted to try my hand at modifying the Shapes example so that I can
play around with GEF. However, I am unable to get the project up and
running. I have tried it n times and is really getting frustating for
me. I am missing something silly may be.
This is what I have been trying.
Approach I
1) Create a new Multi-page editor plugin project
2) Remove the default created java classes and replace them with the
shapes src files (the whole org package).
3) Refresh the project to get the new files.
4) Add the GEF/Draw2D and UI-Views plugins as dependencies (also tried
adding them as external jars in build path and not dependencies).
5) Change plugin.xml to reflect the new class names for editor, plugin
and wizard
Approach II
1) Create a simple empty project
2) Get the .project, .classpath, plugin.xml files from the CVS for the
shapes example ( [Tools_Project] / org.eclipse.gef.examples.shapes /)
and copy them into the empty project.
3) Copy the shape src files into the src dir of this project.
In both the above cases I don't get a single error in compilation.
However when I try to run in a new workbench I first get
ExceptionInInitialzerError and then later a NoClassDefFound error for
the Editor.
Similarly I get errors with the wizard.
I removed the shapes plugin from the main eclipse plugin dir and edited
the feature.xml file in the feature/gif-examples dir to make sure that
there isn't a clash between my project and the installed shape example
plugin.
Any clues/suggestions for me?
Re: Creating Eclipse projects from the example sources [message #154280 is a reply to message #154243] |
Fri, 15 October 2004 15:47 |
Pratik Shah Messages: 1077 Registered: July 2009 |
i.e., right-click in Package Explorer, Import -> External plugins and
fragments.
Also, once you've imported it in your workspace, remember that the runtime
target should include the project in the workspace (that has your changes)
and not the one in the plug-ins directory. To fix this, Window ->
Preferences -> Plugin Development -> Target Platform and click on "Not in
workspace."
"Ranjit" <ranjit@notMyId.com> wrote in message
news:cknmqv$oeh$1@eclipse.org...
> Approach I
> and wizard
> Approach II
> the Editor.
> plugin.
> Thanks
Re: Creating Eclipse projects from the example sources [message #154550 is a reply to message #154243] |
Tue, 19 October 2004 05:19 |
Ranjit wrote:
Randy and Pratik,
Thanks for your suggestions, it worked like a charm as you suggested.
-Ranjit
FUDForum. Page generated in 0.03302 seconds
