Home » Eclipse Projects » Eclipse Platform » wizard scenario that is imposible under eclipse
wizard scenario that is imposible under eclipse [message #154089] Fri, 07 November 2003 11:36 Go to next message
Originally posted by: nospam.nospam.org
I am creating a wizard. the second page should be added or not based on the
selection on the first page.
Is this possible?
Re: wizard scenario that is imposible under eclipse [message #154105 is a reply to message #154089] Fri, 07 November 2003 12:18 Go to previous messageGo to next message
Originally posted by: janestockdill.hotmail.com
Just an idea as I'm just learning about wizards myself. Could you add a
listener to the control you are using for the selection
then dynamically create the page and add it. Not sure how well this would
work if the user changed there mind several times as
I can't see a way to remove a page.
Something along the lines of the below to the listener code ??
MyWizard wizard = ((MyWizard)getWizard());
wizard.page3 = new MyWizardPage();
wizard.addPage(wizard.page3);
Let me know if you find the answer as this would be helpful to me too.
Jane
"Alex" <nospam@nospam.org> wrote in message news:boghh5$4t5$1@eclipse.org...
the
> Is this possible?
Re: wizard scenario that is imposible under eclipse [message #154256 is a reply to message #154105] Fri, 07 November 2003 14:47 Go to previous message
WizardPage.canFlipToNextPage() worked for me
"Jane Stockdill" <janestockdill@hotmail.com> wrote in message
news:bogk83$81j$1@eclipse.org...
> Thanks
> Jane
> the
> > Is this possible?
Previous Topic:JVM terminated. Exit Code=1
Next Topic:"The project cannot be built until build path errors are resolved."
Current Time: Tue Sep 16 18:13:07 EDT 2025
Powered by FUDForum. Page generated in 0.05658 seconds
