Home » Language IDEs » ServerTools (WTP) » WTP 1.0 - failing when moving generated WSDL file
WTP 1.0 - failing when moving generated WSDL file [message #153875] Tue, 27 December 2005 09:01 Go to next message
Originally posted by: tony_ross.mac.com
I am attempting to do the 'Creating Bottom Up Web Service' tutorial -
but the wizard is failing with the following exception. I am running
Eclipse 3.1.1 & WTP 1.0 on my Mac running OS X 10.4.3. The /Users
directory does exist.
Any ideas
WAB0523E Error moving resource: Resource /Users does not exist.
org.eclipse.core.internal.resources.ResourceException: Resource
org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:304)
org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:172)
org.eclipse.core.internal.resources.Project.checkAccessible( Project.java:124)
org.eclipse.core.internal.resources.Folder.assertCreateRequi rements(Folder.java:30)
at org.eclipse.core.internal.resources.Folder.create(Folder.jav a:90)
at org.eclipse.core.internal.resources.Folder.create(Folder.jav a:121)
org.eclipse.wst.command.internal.env.common.FileResourceUtil s.makeFolder(FileResourceUtils.java:557)
org.eclipse.wst.command.internal.env.common.FileResourceUtil s.makeFolderPath(FileResourceUtils.java:517)
org.eclipse.wst.command.internal.env.common.FileResourceUtil s.makeFolderPath(FileResourceUtils.java:514)
org.eclipse.wst.command.internal.env.common.FileResourceUtil s.createFile(FileResourceUtils.java:376)
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja va2WSDLCommand.moveGeneratedWSDL(Java2WSDLCommand.java:195)
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja va2WSDLCommand.executeAntTask(Java2WSDLCommand.java:164)
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja va2WSDLCommand.execute(Java2WSDLCommand.java:87)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:386)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:327)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:226)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$5.run(SimpleCommandEngineManager.java:247)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:217)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:78)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.performFinish(WizardPageManager.java:227)
org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizar d.performFinish(DynamicWizard.java:335)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1380)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1404)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1389)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 237)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3060)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2712)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:126)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:246)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: WTP 1.0 - failing when moving generated WSDL file [message #154702 is a reply to message #153875] Tue, 03 January 2006 19:18 Go to previous message
Is your project stored outside your workspace directory?
Then this may be the same problem as bug # 121199.
Previous Topic:JSR 88 support in WTP 1.0
Next Topic:WTP logo
Current Time: Fri Apr 25 21:38:51 EDT 2025
Powered by FUDForum. Page generated in 0.03875 seconds
