Home » Eclipse Projects » GEF » NPE when model implements IPropertySource
NPE when model implements IPropertySource [message #153849] |
Wed, 13 October 2004 16:08 |
Originally posted by: gayatri.us.ibm.com
I have made my model objects as implementors of IPropertySource. These
model objects are actually adapters that are wrappering the actual EMF
model objects.
My problem is, when I make them implement the IPropertySource, when I
click on the corresponding editpart I get the following NPException. I
am not able to figure out what is causing this, but somehow when I
remove the IPropertySource implementation from the model adapters, I
don't get this error. Help!!
org.eclipse.gef.tools.ToolUtilities.getSelectionWithoutDepen dants(ToolUtilities.java:36)
org.eclipse.gef.tools.DragEditPartsTracker.createOperationSe t(DragEditPartsTracker.java:150)
org.eclipse.gef.tools.AbstractTool.getOperationSet(AbstractT ool.java:574)
org.eclipse.gef.tools.DragEditPartsTracker.captureSourceDime nsions(DragEditPartsTracker.java:108)
org.eclipse.gef.tools.DragEditPartsTracker.setState(DragEdit PartsTracker.java:526)
org.eclipse.gef.tools.AbstractTool.stateTransition(AbstractT ool.java:1245)
org.eclipse.gef.tools.SelectEditPartTracker.handleButtonDown (SelectEditPartTracker.java:93)
at org.eclipse.gef.tools.AbstractTool.mouseDown(AbstractTool.ja va:965)
org.eclipse.gef.tools.SelectionTool.mouseDown(SelectionTool. java:481)
at org.eclipse.gef.EditDomain.mouseDown(EditDomain.java:197)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Pressed(DomainEventDispatcher.java:312)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown( LightweightSystem.java:491)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:132)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:41)
at java.lang.reflect.Method.invoke(Method.java:371)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Re: NPE when model implements IPropertySource [message #153859 is a reply to message #153849] |
Wed, 13 October 2004 16:40 |
The GraphicalViewer is getting a FocusLost event during the callback for
MouseDown. Find out why focus is being lost. Put a breakpoint in
SelectionTool#handleFocusLost(), and find out what is causing the canvas to
lose focus.
We will fix this bug in 3.1 such that the NPE will not occur. However, if
the canvas looses focus, the mouse drag/press is aborted. So it would not
be possible to select and drag an editpart all at once if you are losing
focus when the part is selected.
"Gayatri Renganathan" <gayatri@us.ibm.com> wrote in message
news:ckjjji$oi2$1@eclipse.org...
> model objects.
> java.lang.NullPointerException
> at
ies.java:36)
> at
racker.java:150)
> at
> at
> at
a:526)
> at
> at
racker.java:93)
> at
> at
> at
> at
m.java:491)
> at
> at
Code))
> at
> at
> at
> at
> at
> at
java:335)
> at
> at
> at
> at
..java:41)
Re: NPE when model implements IPropertySource [message #153867 is a reply to message #153859] |
Wed, 13 October 2004 17:02 |
Hi Randy,
Thanks for the quick response. I put a stop at the focusLost method in
Selection tool and I am attaching the stack trace at that point. Is
there any way to fix this problem without having to upgrade to the
latest version? If so, how? thanks!!
> SelectionTool.handleFocusLost() line: 227
> SelectionTool(AbstractTool).focusLost(FocusEvent, EditPartViewer) line: 420
> DefaultEditDomain(EditDomain).focusLost(FocusEvent, EditPartViewer) line: 89
> DomainEventDispatcher.dispatchFocusLost(FocusEvent) line: 215
> LightweightSystem$EventHandler.focusLost(FocusEvent) line: 341
> TypedListener.handleEvent(Event) line: 108
> EventTable.sendEvent(Event) line: 82
> FigureCanvas(Widget).sendEvent(Event) line: 796
> FigureCanvas(Widget).sendEvent(int, Event, boolean) line: 820
> FigureCanvas(Widget).sendEvent(int) line: 801
> FigureCanvas(Control).sendFocusEvent(int, int) line: 1756
> FigureCanvas(Control).WM_KILLFOCUS(int, int) line: 3614
> FigureCanvas(Canvas).WM_KILLFOCUS(int, int) line: 233
> FigureCanvas(Control).windowProc(int, int, int, int) line: 2999
> Display.windowProc(int, int, int, int) line: 3338
> OS.DefWindowProcW(int, int, int, int) line: not available [native method]
> OS.DefWindowProc(int, int, int, int) line: 1462
> Shell.callWindowProc(int, int, int) line: 398
> Shell(Control).windowProc(int, int, int, int) line: 3050
> Shell(Decorations).windowProc(int, int, int, int) line: 1391
> OS.BringWindowToTop(int) line: not available [native method]
> Shell(Decorations).bringToTop() line: 180
> Shell.open() line: 757
> MessageDialog(Window).open() line: 644
> MessageDialog.openError(Shell, String, String) line: 295
> AbstractSelectionService$3(SafeRunnable).handleException(Thr owable) line: 52
> InternalPlatform.handleException(ISafeRunnable, Throwable) line: 349
> InternalPlatform.run(ISafeRunnable) line: 617
> Platform.run(ISafeRunnable) line: 747
> PageSelectionService(AbstractSelectionService).fireSelection (IWorkbenchPart, ISelection) line: 151
> AbstractSelectionService$1.selectionChanged(SelectionChanged Event) line: 66
> MultiPageSelectionProvider$1.run() line: 70
> InternalPlatform.run(ISafeRunnable) line: 615
> MultiPageSelectionProvider.fireSelectionChanged(SelectionCha ngedEvent) line: 68
> MultiPageEditorSite.handleSelectionChanged(SelectionChangedE vent) line: 299
> MultiPageEditorSite$1.selectionChanged(SelectionChangedEvent ) line: 247
> TuiGraphicalViewer(AbstractEditPartViewer).fireSelectionChan ged() line: 220
> TuiGraphicalViewer(AbstractEditPartViewer).appendSelection(E ditPart) line: 151
> TuiGraphicalViewer(AbstractEditPartViewer).select(EditPart) line: 538
> DragEditPartsTracker(SelectEditPartTracker).performSelection () line: 205
> DragEditPartsTracker(SelectEditPartTracker).performCondition alSelection() line: 151
> DragEditPartsTracker(SelectEditPartTracker).handleButtonDown (int) line: 85
> DragEditPartsTracker(AbstractTool).mouseDown(MouseEvent, EditPartViewer) line: 965
> SelectionTool.mouseDown(MouseEvent, EditPartViewer) line: 481
> DefaultEditDomain(EditDomain).mouseDown(MouseEvent, EditPartViewer) line: 197
> DomainEventDispatcher.dispatchMousePressed(MouseEvent) line: 312
> LightweightSystem$EventHandler.mouseDown(MouseEvent) line: 491
> TypedListener.handleEvent(Event) line: 132
> Display.runDeferredEvents() line: 2772
> Display.readAndDispatch() line: 2431
> Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 1377
> Workbench.runUI() line: 1348
> Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 254
> PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 141
> IDEApplication.run(Object) line: 96
> PlatformActivator$1.run(Object) line: 335
> EclipseStarter.run(Object) line: 273
> EclipseStarter.run(String[], Runnable) line: 129
> NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
> NativeMethodAccessorImpl.invoke(Object, Object[]) line: 79
> DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 41
> Method.invoke(Object, Object[]) line: 371
> Main.basicRun(String[]) line: 183
> Main.run(String[]) line: 644
> Main.main(String[]) line: 628
> lose focus.
>>Hi,
>>model objects.
>> at
> ies.java:36)
>> at
> racker.java:150)
>> at
>> at
>> at
> a:526)
>> at
>> at
> racker.java:93)
>> at
>> at
>> at
>> at
> m.java:491)
>> at
>> at
> Code))
>> at
>> at
>> at
>> at
>> at
>> at
> java:335)
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
> ..java:41)
Re: NPE when model implements IPropertySource [message #153883 is a reply to message #153867] |
Wed, 13 October 2004 17:34 |
It looks like a previous exception is in the process of being logged and
shown to the user, which is causing a secondary exception to occur.
to reproduce the *real* exception, try changing selection using the keyboard
instead of the mouse. Use the arrow keys processed by
GRaphicalViewerKeyHandler.
news:ckjmq5$vjp$1@eclipse.org...
> Hi Randy,
420
line: 89
method]
line: 52
66
line: 68
299
220
line: 151
line: 151
85
line: 965
line: 197
to
> > lose focus.
if
not
> >>Hi,
> >>model objects.
> >> at
> > ies.java:36)
> >> at
> > racker.java:150)
> >> at
> >> at
> >> at
> > a:526)
> >> at
> >> at
> > racker.java:93)
> >> at
> >> at
> >> at
> >> at
> > m.java:491)
> >> at
> >> at
> > Code))
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> > java:335)
> >> at
> >> at
> >> at
> >> at
> > ..java:41)
Current Time: Mon Jul 22 20:42:38 GMT 2024
Powered by FUDForum. Page generated in 0.04560 seconds
