Problem with RMI in eclipse (ClassNotFound) [message #153486] |
Thu, 06 November 2003 11:20 |
Originally posted by: lilith.al-jadiri.bmw-carit.de
I am writing a certain plug-in where I have to invoke a method of a MBean
running on a JMX server. I added the .jar(where the .class files are in)
of that MBean as external jars to my project. There is no problem with
compiling my code and invoking the method; however, I get an error at
runtime back because the return type of the method invoked can't be found
although the .class is in the jar file included. It would be great if
anyone can help ASAP .Here is my code snippet followed by the error
message:
System.setSecurityManager(new RMISecurityManager());
Properties p = System.getProperties();
p.put(Context.INITIAL_CONTEXT_FACTORY,
"com.sun.jndi.rmi.registry.RegistryContextFactory");
p.put(Context.PROVIDER_URL, "rmi://localhost:1099");
JRMPConnector connector = new JRMPConnector();
String jndiName = "jrmp";
connector.connect(jndiName, p);
// Get the remote MBeanServer from the connector
// And use it as if it is an MBeanServer
RemoteMBeanServer remoteServer = connector.getRemoteMBeanServer();
ObjectName objName = new ObjectName("de.bmw.VCM:type=management");
try{
Object result =
remoteServer.invoke(objName,"getUnits",new Object[]{new Integer(1)},new
String[]{"java.lang.Integer"});
}catch (javax.management.RuntimeMBeanException rme) {
if (rme.getTargetException() != null) {
rme.getTargetException().printStackTrace();
} else {
rme.printStackTrace();
the "result" return object is from type "de.bmw.ECU" , the .class of that
class happens to be in the external jar included in the project. Here is
the error stack:
ava.rmi.UnmarshalException: Exception while reading result; nested
exception is:
java.lang.ClassNotFoundException: de.bmw.vcm.ECU
at mx4j.adaptor.rmi.RMIAdaptor_Stub.invoke(Unknown Source)
at mx4j.connector.rmi.RMIConnector.invoke(RMIConnector.java:186 )
mx4j.connector.rmi.RMIConnector$RemoteMBeanServerImpl$Handle r.invoke(RMIConnector.java:548)
at $Proxy0.invoke(Unknown Source)
mx4j.connector.rmi.RMIConnector$RemoteMBeanServerImpl.invoke (RMIConnector.java:411)
at de.bmw.example.views.TestgetMBean.<init>(TestgetMBean.java:77)
at de.bmw.example.views.DeviceView.<init>(DeviceView.java:79)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:2 74)
at java.lang.Class.newInstance0(Class.java:306)
at java.lang.Class.newInstance(Class.java:259)
thanks,
Lilith
Anyone out there??? [message #153540 is a reply to message #153486] |
Thu, 06 November 2003 15:06 |
Aljadiri wrote:
> message:
> try{
> Object result =
> } else {
> the error stack:
> exception is:
> at
> at
> at
> at
> thanks,
> Lilith
Re: Anyone out there??? [message #153545 is a reply to message #153540] |
Thu, 06 November 2003 15:10 |
Originally posted by: vgusev.graphlogic.com
Is this jar in your plugin.xml file?
"Aljadiri" <lilith.al-jadiri@bmw-carit.de> wrote in message
news:bodo24$65d$1@eclipse.org...
> Aljadiri wrote:
> > Hi,
MBean
found
> > message:
> > try{
> > Object result =
Integer(1)},new
> > } else {
that
> > the error stack:
> > exception is:
> > at
ector.java:548)
> > at
va:411)
> > at
sorImpl.java:39)
> > at
> > thanks,
> > Lilith
Re: Anyone out there??? [message #153551 is a reply to message #153545] |
Thu, 06 November 2003 15:24 |
Yes I do!!!
Lilith
> > Aljadiri wrote:
> > > Hi,
> MBean
> found
> > > message:
> > > try{
> > > Object result =
> Integer(1)},new
> > > } else {
> that
> > > the error stack:
> > > exception is:
> > > at
> ector.java:548)
> > > at
> va:411)
> > > at
> sorImpl.java:39)
> > > at
> > > thanks,
> > > Lilith
Re: Anyone out there??? [message #153553 is a reply to message #153551] |
Thu, 06 November 2003 15:35 |
How about the Eclipse class loader issue then? It is described in FAQ. One
has to set up classloader explicitely in some cases.
news:bodp2l$7d2$1@eclipse.org...
> Yes I do!!!
> Lilith
> > > Aljadiri wrote:
> > > > Hi,
> > MBean
in)
with
> > found
if
> > > > message:
> > > > try{
> > > > Object result =
> > Integer(1)},new
> > > > } else {
> > that
Here is
> > > > the error stack:
> > > > exception is:
> > > > at
> > ector.java:548)
> > > > at
> > va:411)
Method)
> > > > at
> > sorImpl.java:39)
> > > > at
> > > > thanks,
> > > > Lilith
FUDForum. Page generated in 0.03458 seconds
