Home » Eclipse Projects » Eclipse Platform » More on Eclipse and ClearCase
More on Eclipse and ClearCase [message #152774] |
Tue, 04 November 2003 11:14  |
A while ago I got some help from David Wegener (see below).
I followed his instructions, thanks David, and I now have an environment
setup for me.
We use different versions of the same java source tree (using labels in
the config spec). Each version is a release with specific functionality.
Here are my follow-up questions:
* Lets say that we have made a couple of releases and that we must go back
to release and make corrections ( not too unusual).The person making the
correction does he/she have to make an import into the workspace again of
the older version. That is, the most current proejct is contained in the
workspace and when other versions is needed we import them?
* If we make any changes to the common perferences/settings in the dot
files then we have to import project again or ....?
All help is very much appreciated.
//Mikael Petterson
Ps. Is this the right forum for my questions.
Re: More on Eclipse and ClearCase [message #153009 is a reply to message #152853] |
Wed, 05 November 2003 09:09   |
Hi Dave,
I am getting more confused.
Question 1.
I tried to download the clearcase plug-in from rational. When I click the
link you sent me I get the following in the browser window:
http://www-140.ibm.com/developerworks/rational
Then I click the following link:
Add-ins, plug-ins, and scripts
ClearCase
Plug-ins - Get the IBM Rational ClearCase SCM adapters for Eclipse 2.0 for
both Windows and Linux.
I am using Solaris 8 and it seems like the plugin does not work with my
os?!
Question 2
You suggest to have a separate workspace when I make changes to an old
version. I don't get the whole picture.
I have the following source tree in clearcase:
/vobs/rbs/sw/rbssw1/boam_subsys/src/se/ericsson.......
If I create the boam project one time and set workspace to
/vobs/rbs/sw/rbssw1/boam_subsys a directory called boam will be created and
it will contain .classpath and .project files ( all dot files). I make
elements of them all and check them in.
When a team member shall work with the project boam the config spec sets
which version that the user will "see". Then the user starts up the
eclipse with the -data /vobs/rbs/sw/rbssw1/boam_subsys as workspace and
imports the project boam.
Is this ok to do or what could be the drawbacks and what is your advice to
handle it ( please refer to my example).
Is there another way to make sure that the .project .classpath will be
loaded each time we work on a a specific increment (decided by config
spec.)?
I appreciate your advice and it is valuble for the credability of eclipse.
//Mikael
Dave Wegener wrote:
> Mikael Petterson wrote:
> > Hi,
> > setup for me.
> My suggestion would be to create a separate workspace for making changes
> to an old version. If you use the Rational plugin, you can then use the
> Add existing WSAD project to workspace. This keeps your work separate and
> helps prevent confusion when looking at code in the editor.
> If you have the dot files under Clearcase control, then checking the files
> in will make them available to everyone who can see them in their config
> spec. Stopping and restarting Eclipse should pick and of these changes up.
> > //Mikael Petterson
Re: More on Eclipse and ClearCase [message #153147 is a reply to message #153009] |
Wed, 05 November 2003 12:35   |
> Hi Dave,
> Question 1.
> ClearCase
> os?!
> Question 2
> spec.)?
We work with ClearCase under Windows, so we use it a little differently.
We have multiple views active at a time, each mapped to its own drive
letter. In this mode, each view has its own directory structure and you
can work on both simultaneously by bringing up different instances of
Eclipse each pointing to a different workspace.
I have also seen people switch which view is assigned to their workspace
drive letter. This works as well. However, you have to make sure that
you bring down eclipse prior to making the change. When you bring Eclipse
back up, you need to perform a refresh for the project. The refresh will
make sure that everything is built properly.
You should be able to work similarly to this second method. One thing I
would recommend is to not have your workspace residing in your ClearCase
view. Define you workspace to be in a separate location within your home
directory. When you define your project, uncheck the Use Default Location
and point to the ../boam directory. The workspace location is for
personal preferences that really shouldn't be in ClearCase. The project
location is what you want in ClearCase.
As long as the .project and .classpath files are ClearCase elements, the
config spec should insure that you are looking at the version that is
appropriate for your specific increment. Eclipse will read these files
each time it starts up. After switching the config spec, you should
perform a Rebuild All. Without it, you could have old class files that
are left from compiles under the old config spec.
> //Mikael
> > > Hi,
> > > setup for me.
back
> > > //Mikael Petterson
Re: More on Eclipse and ClearCase [message #153724 is a reply to message #153147] |
Thu, 06 November 2003 14:18  |
> > Hi Dave,
> > Question 1.
> > ClearCase
> > os?!
> > Question 2
> > spec.)?
Ok! I think working like method 2 is fine.
I will have a workspace for each increment in my home directory like this:
/home/eraonel/increment2
/home/eraonel/increment3
/home/eraonel/increment4 and so forth.
This is also true for my fellow members. So when they make an import of
the boam project ( for a let's say increment 3) it will be put in their
workspace
/home/userid/increment3.
The boam directory will contain all COPIES of dot files (.project and
classpath) that are checkedin in clearcase?
So if there is a change of let's say path to jar's (change in .classpath)
in a specific increment it means that all team mates must reimport the
boam project or .....?
Thanks again.
//Mikael
> > Regards,
> > //Mikael
> > > > Hi,
environment
> > > > setup for me.
functionality.
> back
the
of
the
and
files
up.
> > > > //Mikael Petterson
Current Time: Wed Sep 17 05:57:14 EDT 2025
Powered by FUDForum. Page generated in 0.05376 seconds
