Block/Column move in CDT editor [message #152715] |
Wed, 31 August 2005 10:19 |
Originally posted by: steveb.imperas.com
We're planning to switch enmass toCDT in the near future and 1 question
keeps cropping up to which I can find no answer.
Is there a way to do block/column move in the CDT editor?
Thank you,
Steve
Re: Block/Column move in CDT editor [message #153003 is a reply to message #152865] |
Fri, 02 September 2005 08:07 |
Andre,
Thanks for the pointer. This almost does what we want, but not quite. We
make extensive use of table driven code (in C) and there is a frequent need
to insert, remove and realign/move columns. So what is required is the
ability to select a rectangular block of text i.e. a column (not necessarily
starting at the first line) and then do a cut, copy, move etc. Any thoughts?
Steve
"Andr
Re: Block/Column move in CDT editor [message #153012 is a reply to message #153003] |
Fri, 02 September 2005 09:07 |
Andrés Wellmann Jelic Messages: 32 Registered: July 2009 |
Member |
No, this is the only plugin which I know for these purposes. The only good
external
alternative which I know is Emacs which has very good formating
capabilities.
sorry
andrés
Am Fri, 02 Sep 2005 10:07:10 +0200 schrieb Steven Bird
<steveb@imperas.com>:
> Andre,
> need
> necessarily
> thoughts?
> Steve
> "Andrés" <ponch@gmx.de> wrote in message
> news:op.swezqvaeqhjsen@we.inf.bi.ruhr-uni-bochum.de...
>> you should take a look at the plugin "net.sf.lunar_eclipse.editing"
>> where
>> you
>> can cut/copy/paste/delete rectangulars like in emacs. Is this the
>> feature
>> which
>> you are looking for??
>> andrés
>> Am Wed, 31 Aug 2005 12:19:56 +0200 schrieb Steven Bird
>>> Thank you,
>>> Steve
>> Erstellt mit Operas
Written with Opera
FUDForum. Page generated in 0.02986 seconds
