Home » Language IDEs » Java Development Tools (JDT) » what is the status of JPDA strata (JSR-045) support and SourceLocator support
Re: what is the status of JPDA strata (JSR-045) support and SourceLocator support [message #152642 is a reply to message #152624] |
Tue, 06 April 2004 10:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: daniel.rohe.stud.tu-ilmenau.de
"Dan Jacobs" <djacobs@jplates.com> schrieb im Newsbeitrag
news:c4trov$6pl$1@eclipse.org...
> Hi all,
> I haven't seen any discussion about JPDA strata support in the archives
> since two years ago. Does Eclipse support it already? I had assumed that
> it didn't (and have been trying to do things the hard way).
> If Eclipse does provide JPDA strata support, is there any documentation on
> how to work generate SMAP files/data in the build process? Or is it
> necessary to post-process the class files manually (not a big deal using
> BCEL) after the Java builder runs?
> If Eclipse does *not* yet have JPDA strata support, is there a planned
> timetable for it?
Strata support is in Eclipse 3.0, i've looked in source code.
Theoretically for JSP the JSP compiler must also have strata support. I
think then the JSP compiler must generate the SMAP based on the generated
Java-File and the given JSP-file.
greetings
Daniel
Re: what is the status of JPDA strata (JSR-045) support and SourceLocator support [message #152729 is a reply to message #152642] |
Tue, 06 April 2004 15:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dan Jacobs![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=djacobs%40jplates.com) Messages: 13 Registered: July 2009 |
Junior Member |
Well, that's interesting, because I just re-enabled my SMAP generation and
have added the SourceDebugExtension attribute to the class-files, and the
Eclipse debugger completely ignores those attributes.
As far as I can tell, the JavaSourceLocator is still 100% Java-centric, so
extending a Java-project with other languages still seems to require a new
SourceLocator.
Can anyone from the Eclipse project confirm this and offer some guidance on
the right way to direct the debugger to use the *real* source file?
I am modifying the ClassName attribute in the class-file to point to my
JPlates source file, and adding a properly formed SourceDebugExtension SMAP
attribute, but the debugger does not open or use the JPlates sources, but
always resolves classes to the generated Java sources.
-- Dan
>>Hi all,
>>timetable for it?
> greetings
> Daniel
Re: what is the status of JPDA strata (JSR-045) support and SourceLocator support [message #152757 is a reply to message #152729] |
Tue, 06 April 2004 16:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Excuse me for my name! I've not set up my newsreader correctly. Now it works
correct.
So far i've looked at classes in org.eclipse.jdt.debug.core and
org.eclipse.jdt.internal.debug.core.breakpoints JDT supports stratum
breakpoints. The classes org.eclipse.jdt.debug.core.JDIDebugModel and
org.eclipse.jdt.internal.debug.core.breakpoints.JavaStratumL ineBreakpoint
may be interesting for you.
Correct me if I misunderstand your problem:
You have a project with JPlates template files which are compiled to Java
source files and then the Java compiler creates Java class files. JPlates
says it can generate a mapping between Java source file locations and
JPlates locations, so this would be no problem. Your problem is the lookup
of JPlates files in your project.
If you have problems during build you may create a plugin with a nature for
the JPlates project and a builder which generates the Java source files and
forwards them to the Java builder.
If you have problems when debugging your JPlates project you have to
implement some launching facilities and a source locator. Good help will be
the JDT launching plugin. For source lookups look at the source in the
package org.eclipse.jdt.launching.sourcelookup. There is one source locator
and some source location's. So in my opinion you have to implement the
interface IJavaSourceLocation for your projects which will find the files.
greetings
Daniel
news:4072C9B1.6060300@jplates.com...
> SourceLocator.
on
SMAP
> -- Dan
Re: what is the status of JPDA strata (JSR-045) support and SourceLocator support [message #152796 is a reply to message #152757] |
Tue, 06 April 2004 19:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Junior Member |
Hi Daniel,
My comments are mixed in below.
-- Dan
> correct.
Yes, I see them, but I don't see evidence that they're being used the way I
would have expected.
That's what I'm doing. I have *added* JPlatesNature to a Java project, and
I compile JPlates sources into Java sources. Then, my resource-change
listener watches for class-files being created by the Java-builder, and I
post-process the class-files that were originally from JPlates sources to
store a SMAP-entry and to change the SourceFile attribute.
I agree that seems to be necessary, but I don't it's supposed to be. The
class-files have all the information they need for the debugger to know
exactly what line of what file to go to, but the default source-locator for
Java-projects doesn't use that information. That's the problem.
JSR-045 specifies what other-language compilers are supposed to do in order
for debuggers to support them, but Eclipse hasn't [yet] caught up to
supporting it.
> Good help will be
In principle you're right. But there's an awful lot code that needs to be
nearly duplicated from the JavaSourceLocator and all of its associated
classes. What that default source-locator should be doing is using the
information available to it. For instance, it should used the SourceFile
attribute in the class-file, but instead it assumes a file extension of
".java" in all cases.
Now that I know more about what's going on, I suppose I should submit a bug
report or two.
Thanks again!
-- Dan
> greetings
> Daniel
>>SourceLocator.
> on
> SMAP
>>Thanks,
>>-- Dan
Re: what is the status of JPDA strata (JSR-045) support and SourceLocator support [message #152812 is a reply to message #152796] |
Tue, 06 April 2004 20:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Darin Swanson![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=Darin_Swanson%40us.ibm.com) Messages: 2386 Registered: July 2009 |
Discussion has started in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=57644
HTH
Darins
"Dan Jacobs" <djacobs@jplates.com> wrote in message
news:407300A3.6050500@jplates.com...
> Hi Daniel,
> -- Dan
works
> > correct.
I
Java
JPlates
lookup
for
and
and
for
order
> supporting it.
> > Good help will be
locator
files.
bug
> report or two.
> Thanks again!
> -- Dan
> > greetings
> > Daniel
and
the
so
new
> >>SourceLocator.
> > on
> > SMAP
but
> >>Thanks,
> >>-- Dan
Current Time: Thu Jul 18 04:29:55 GMT 2024
Powered by FUDForum. Page generated in 0.04530 seconds
