Problem with runing Eclipse 3.0 M4 [message #152604] |
Mon, 03 November 2003 22:30 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: kmaxim.a-teleport.com
Hi all,
I cannot run Eclipse 3.0 M4 (but Eclipse 2.1.1 and Eclipse 3.0 M3 work
properly).
I have this exception:
JVM terminated. Exit code=1
D:\jdk1.3\jre\bin\javaw.exe
-cp D:\Eclipse3\startup.jar org.eclipse.core.launcher.Main
-os win32
-ws win32
-arch x86
-showsplash D:\eclipse3\eclipse.exe -showsplash 600
What can I do?
Regards, Maxim
Re: Problem with runing Eclipse 3.0 M4 [message #152612 is a reply to message #152604] |
Mon, 03 November 2003 23:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jean Couillaud![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=couillaud%40fimasys.fr) Messages: 184 Registered: July 2009 |
Maxim Kopeyka wrote:
> Hi all,
> properly).
> D:jdk1.3jrebinjavaw.exe
> -cp D:Eclipse3startup.jar org.eclipse.core.launcher.Main
> -os win32
> -ws win32
> -arch x86
> -showsplash D:eclipse3eclipse.exe -showsplash 600
> What can I do?
Hello, i got this problem too and I solved it by installing the latest JDK
from sun's site. Apparently, the 3.0M4 version doesn't support the jvm
version you're using.
I've not verified the following, but when I tested it, I was using
jdk1.3.1_03.
Eclipse is said (I think I saw that in the release notes) to have been
tested against jdk1.3.1_04. So, that may be you're problem.
Anyway, if you install jdk1.4.2 as I did, it should solve that problem.
You will still be able to use your 1.3.1 jdk for any other applciation,
just launch eclipse with the following arguments (in a shortcut's
properties) "-vm PATH_TO_THE_JDK1.4.2"
PS: I've not tested it either, but I think it should work with any 1.4.x
version
> Regards, Maxim
Hope this help,
Jean
Re: Problem with runing Eclipse 3.0 M4 [message #152720 is a reply to message #152612] |
Tue, 04 November 2003 12:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jean,
Big thanks, JDK 1.4.2 resolved this problem.
Regards, Maxim.
>>Hi all,
>>properly).
>>-os win32
>>-ws win32
>>-arch x86
>>What can I do?
> jdk1.3.1_03.
> version
>>Regards, Maxim
> Hope this help,
> Best regards,
> Jean
Re: Problem with runing Eclipse 3.0 M4 [message #152733 is a reply to message #152612] |
Tue, 04 November 2003 14:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: jgangemi.yahoo.com
i don't believe sdk 1.4.0 works properly.
i received the same type of errors when i tried to launch my plugin usine
1.4.0 (altho i could code and use eclipse ok).
after i upgraded, everything seemed to work ok tho.
On Mon, 3 Nov 2003 23:24:43 +0000 (UTC), couillaud@fimasys.fr (Jean Couillaud)
>version
FUDForum. Page generated in 0.03120 seconds
