Home » Eclipse Projects » Eclipse Platform » Ant plugin in separate jre
Ant plugin in separate jre [message #152536] Mon, 03 November 2003 18:59 Go to next message
Originally posted by: brianf_msn.infinity.nu
Is there a way to make the ant plugin ALWAYS use a separate jre? It's kindof
annoying to have to keep remembering to set it up to avoid the ant memory
leak.
Re: Ant plugin in separate jre [message #152546 is a reply to message #152536] Mon, 03 November 2003 19:07 Go to previous messageGo to next message
Darin Swanson is currently offline Darin SwansonFriend
Not currently.
Note
https://bugs.eclipse.org/bugs/show_bug.cgi?id=45899 which I have tagged to
be included in 3.0 M5
Darins
"Brian Fox" <brianf_msn@infinity.nu> wrote in message
news:bo68fg$aa$1@eclipse.org...
kindof
> leak.
Re: Ant plugin in separate jre [message #152571 is a reply to message #152546] Mon, 03 November 2003 19:25 Go to previous messageGo to next message
Sweet, given the memory issues I agree the default should be the other way.
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:bo68pr$n0$1@eclipse.org...
> Not currently.
> Note
> Darins
> kindof
memory
> > leak.
Re: Ant plugin in separate jre [message #155950 is a reply to message #152546] Wed, 12 November 2003 16:34 Go to previous messageGo to next message
Originally posted by: j.warmer.klasse.nl
I spent a day trying to find a way to have the ant task run in a
separate JRE. No luck.
Looking at messages like the one below I know this must be possible.
I searched the eclipse archives, google and thge online help but
could not find it. Can you tell me how I have to set this up ?
Jos Warmer
jos.warmer@xs4all.nl
On Mon, 3 Nov 2003 11:07:31 -0800, "Darin Swanson"
<Darin_Swanson@us.ibm.com> wrote:
>Not currently.
>Note
>Darins
>kindof
>> leak.
Re: Ant plugin in separate jre [message #156203 is a reply to message #155950] Thu, 13 November 2003 07:53 Go to previous message
You need to have a 3.0 M3 build or later and configure the JRE tab for the
Ant launch configuration
Darins
"Jos Warmer" <j.warmer@klasse.nl> wrote in message
news:s5o4rv8g1uljti028h71ig4dtpltbhrhq2@4ax.com...
> Jos Warmer
> >Not currently.
> >Note
to
> >Darins
> >kindof
memory
> >> leak.
Previous Topic:Resource changed events when editor opened and closed?
Next Topic:how to set different values for indent width, tab width
Current Time: Mon Dec 30 18:09:03 GMT 2024
Powered by FUDForum. Page generated in 0.03703 seconds
