Home » Language IDEs » Java Development Tools (JDT) » directing debugger to non-java source editor
directing debugger to non-java source editor [message #152373] Mon, 05 April 2004 11:20 Go to next message
Hi all,
We're developing a pluging for JPlates, which is a template-processing
extension of Java that compiles into Java. See www.jplates.com for more.
We are performing minor surgery on the class files after Eclipse compiles
the generated Java, modifying the SourceFile attribute to point back to the
JPlates source, and the line-number-table to correctly resolve back to the
right line-numbers of the JPlates sources.
I would have thought that the class-file surgery would be enough for the
Eclipse debugger to want to open the appropriate JPlates sources in the
JPlates editor, but instead it opens the [rather less aesthetically
pleasing] generated Java sources in the Java editor.
I have been able to set breakpoints in the JPlates editor, but there must
be some additional magic trick I need to get the debugger to believe that
it should work with the JPlates sources and JPlates editor.
Does anyone know what that magic might be?
Thanks in advance,
Dan Jacobs
President, JPlates Inc.
Re: directing debugger to non-java source editor [message #152586 is a reply to message #152373] Mon, 05 April 2004 22:11 Go to previous message
OK, I know I could earn an odd reputation for responding to my own posts
all the time, but after *much* more searching, I came across a nearly
unrelated reference to ISourceLocator, which I will pursue.
So now my question is: Is there a better approach to becoming a competent
Eclipse developer than stumbling through the API hoping to find something
relevant?
I've got a couple of books (Shavor et al is excellent), but there's a lot
more involved in developing a really sophisticated plugin (such as for
supporting a language that extends Java) that I don't ever expect to see in
a book for the average plugin developer.
Any pointers would be appreciated - but expect more postings (and replies) too.
-- Dan
Dan Jacobs wrote:
> Hi all,
> compiles the generated Java, modifying the SourceFile attribute to point
> back to the JPlates source, and the line-number-table to correctly
> resolve back to the right line-numbers of the JPlates sources.
> must be some additional magic trick I need to get the debugger to
> believe that it should work with the JPlates sources and JPlates editor.
> Thanks in advance,
> Dan Jacobs
Previous Topic:problem with Marker persistence in 3.0 M7
Next Topic:M8: Usability with multiple editors
Current Time: Mon Nov 03 12:28:15 EST 2025
Powered by FUDForum. Page generated in 0.28455 seconds
