Calendar [message #151887] |
Fri, 07 April 2006 12:18 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ciolo.mat.uni.torun.pl
I would like to set-up a calendar control for the input Date parameter in
my BIRT report. Any ideas on how to do this ?
Re: Calendar [message #151923 is a reply to message #151887] |
Fri, 07 April 2006 13:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: m.n.com
Is your application browser based? RCP based? ____ based?
Marcin Ciolo wrote:
> Hi
> in my BIRT report. Any ideas on how to do this ?
Re: Calendar [message #151938 is a reply to message #151933] |
Fri, 07 April 2006 14:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Well, if you are using Java to do the UI, and more specifically JSF,
there is a JSF Calendar component.
Marcin Ciolo wrote:
> browser based
Re: Calendar [message #151941 is a reply to message #151938] |
Fri, 07 April 2006 14:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ok it's some solution, but i use to view report the Birt Report
viever(_frameset) and where i must put the jsf code(in wchich file),
because i don't know.
Re: Calendar [message #152018 is a reply to message #151941] |
Fri, 07 April 2006 16:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Do you current have a web application? Something you are accessing the
reports from? If so, how did you develop it?
FUDForum. Page generated in 0.03746 seconds
