Re: BIRT & Websphere [message #151898 is a reply to message #151815] |
Fri, 07 April 2006 12:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: juergen.schwarz.gefasoft.de
You can set the settings for your app in the Websphere admin console. In
German you have to set the following values:
Set "Modus des Klassenlader" to "PARENT_LAST"
Set "Policy fuer WAR-Klassenlader" to "Anwendung"
This lets WebSphere first load your applications jars. This worked for me.
Wolfgang Herr schrieb:
> I also had to replace the icu4j_3_2.jar File...
> "Wolfgang Herr" <herr@tambas.at> schrieb im Newsbeitrag
> news:e1532m$pva$1@utils.eclipse.org...
>> I deployed the Birt Report Viewer (2.1M5) to a Websphere 6.0 Server (WAS
>> 6.0.2) and I got a Version-clash of the js.jar file.
>> In the WAS\libs there was an older version of the js.jar, so I had to
>> remove this jar and then the sample Report worked as expected.
>> Does anyone know what the WAS uses the js.jar for? Is it unproblemtatic to
>> change the js.jar in the WAS\libs to the version which comes with birt?
>> Thanks
>> Wolfgang
FUDForum. Page generated in 0.03954 seconds
