unedit files in CVS [message #151736] |
Fri, 31 October 2003 08:35 |
Originally posted by: tzach98.hotmail.com
I'm using eclipse 2.1 on win2k.
I try to work with a CVS repository on a Unix machine (CVS 1.11)
From some reason I can team->edit a file, but than both edit/unedit are
disable.
I guess I should redefine some configuration flag, but which?
Thanks.
Re: unedit files in CVS [message #151966 is a reply to message #151736] |
Fri, 31 October 2003 19:49 |
Originally posted by: Michael_Valenta.oti.com
You should be able to unedit a file that was previously edited. CVS
version 1.11 is not suported by Eclipse. Perhaps it's behavior differs
enough from 1.11.1p1 to cause the problem. There is a flag that can be
set in the project CVS properties page that may also help.
Michael
> disable.
> Thanks.
FUDForum. Page generated in 0.03045 seconds
