Home » Language IDEs » C / C++ IDE (CDT) » Program is not recognized as an executable
Program is not recognized as an executable [message #151620] Fri, 19 August 2005 14:26 Go to next message
Originally posted by: berend.chalmers.se
I have an application which I succesfully imported in eclipse using CDT
(although I do not think it matters for my question). Editing and
building works fine. But when creating a run configuration I have the
following problem.
When I run the application outside of eclipse, on a linux or unix-like
OS, I run:
$ mpirun -np 1 ProjectName
where mpirun is a script which is used to distribute the application
over a number of processors (in this case np=1)m, and ProjectName is the
name of the executable. However, when I fill in C/C++ application to be:
mpirun, and the Arguments to be: -np 1 ProjectName
I get the error: Program is not a recognized executable.
How can I overcome this?
Berend.
Re: Program is not recognized as an executable [message #151627 is a reply to message #151620] Fri, 19 August 2005 17:30 Go to previous message
You named it! mpirun is a script, which the debugger is not able to handle.
You might run it as external tool and attach to the process created.
Berend van Wachem schrieb:
> following problem.
> OS, I run:
> Berend.
Previous Topic:how to debug dll under windows
Next Topic:ESQL?
Current Time: Thu Oct 16 21:20:53 EDT 2025
Powered by FUDForum. Page generated in 0.18679 seconds
