Mindmap example [message #151551] |
Wed, 19 September 2007 04:23 |
Originally posted by: jakobsen.avaya.com
I am new to GMF and trying to follow the mindmap application using hte
cheat sheet. I made it through and everything builds fine, but when I
run it I see that my .mindmap files open with the EMF editor instead of
the new GMF editor.
Any suggestions?
Re: Mindmap example [message #151718 is a reply to message #151584] |
Wed, 19 September 2007 18:54 |
Thanks for the replay. That got me a little further.
I think it is the gmf editor that is not getting loaded for some reason.
If I do File->New I do not see the example option as I am supposed
to. I tried looking in the Error Log but no error were logged.
If I do Help->About->Plugins I see
org.eclipse.gmf.graphdef.edit,
org.eclipse.gmf.examples.mindmap.tests,
org.eclipse.gmf.examples.mindmap.edit and
org.eclipse.gmf.examples.mindmap.editor.
Do you think I am missing a plugin for this sample app?
Dennis
Boris Blajer wrote:
> Hi Dennis,
> The created EMF files do in fact open with the EMF editor; this is an
> expected behavior. If you create the Mindmap diagram (or initialize one
> from an existing EMF file), an additional file (by default it should be
> .mindmap_diagram, but may also be .mmd, if it is specified so in your
> mindmap.gmfgen file) will be created. Opening it will bring up the
> diagram editor.
> Best regards,
> Boris
>> of the new GMF editor.
>> Any suggestions?
Re: Mindmap example [message #151725 is a reply to message #151718] |
Wed, 19 September 2007 19:05 |
Stefan Kuhn Messages: 355 Registered: July 2009 |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
most likely .diagram is missing.
- -stefan
> Dennis
> Boris Blajer wrote:
>> Hi Dennis,
>> one from an existing EMF file), an additional file (by default it
>> should be .mindmap_diagram, but may also be .mmd, if it is specified
>> so in your mindmap.gmfgen file) will be created. Opening it will bring
>> up the diagram editor.
>> Best regards,
>> Boris
>>> hte cheat sheet. I made it through and everything builds fine, but
>>> when I run it I see that my .mindmap files open with the EMF editor
>>> instead of the new GMF editor.
>>> Any suggestions?
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFG8XLpIYVWjMSpDwwRAnHlAJ4kVPuKudONooC0cB1Cwc3Qf2LojACf RGdg
bpWYaueP379mEifmuKMdakM=
=uz6u
-----END PGP SIGNATURE-----
FUDForum. Page generated in 0.03714 seconds
