Re: JSP validation errors not showing up ? [message #152547 is a reply to message #151506] |
Thu, 15 December 2005 18:59 |
Max Rydahl Andersen wrote:
> Is it expected behavior that if you have JSP errors AND enabled project
> specific validation settings to validate on each save that
> no errors show in the problem view ?
No, the JSP Validator specifically is enabled AND you have automatic
builds turned on (validation is currently done as part of the build)?
> The project is not a WTP project - is that required ? Is the files
> required to be in a specific place for it to work ?
Not that I'm aware of, but it needs to at least be in a Java-ish
project for us to be able to translate the JSP, compile it, and then
report the errors we find.
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.03474 seconds
