Too large source ?? [message #151495] |
Tue, 30 March 2004 08:26 |
Originally posted by: frode.halvorsen.hoco.no
I am testing som DCOM-bridge software (J-Integra), and did one of the
samples against Excel.
After importing the JAVA-classes into Eclipse, one of the generated classes
is too big :
The code for the static initializer is exceeding the 65535 bytes limit
When doing a manual javac on the same file it compiles fine.
Can this limit be set higfher to avoid this in eclipse ?
Frode Halvorsen
Re: Too large source ?? [message #151596 is a reply to message #151495] |
Tue, 30 March 2004 14:01 |
Originally posted by: olivier_thomannNO.ca.ibm.comSPAM
Le Tue, 30 Mar 2004 10:26:21 +0200, "Frode Halvorsen"
You might be really close to the 64K limit with javac and slightly
above with Eclipse compiler.
No. This is a VM limitation. Could you please open a bug report
against JDT/Core where you provide the source code in a zip file?
Then we should be able to tell you why javac compiles fine and not
Eclipse compiler.
Olivier
FUDForum. Page generated in 0.28969 seconds
