Re: Projects created via CVS checkout [message #151419 is a reply to message #151398] |
Thu, 30 October 2003 11:50 |
Originally posted by: hcs33.egon.gyaloglo.hu
Do you put the .project and .classpath files into CVS for your projects? If
no, consider this (they contains important information of project type,
builders and classpath).
HTH,
Csaba
"Tim Wilkins" <timw@mediatel.co.uk> wrote in message
news:bnqtk1$taf$1@eclipse.org...
> I'm having problems with projects in Eclipse that I create using the
> 'Check Out' facility of the inbuilt CVS client.
> When I create a project normaly in Eclipse I get all the usuual property
> attributes including the 'Java Build Paths' where you can add external
> jar's. However if I create a project by checking out a directory from our
> cvs repository although it appears as a normal project it does not behave
as
> a normal project in Eclipse. It does not have the 'Java Build Paths'
> attribute in the properties and infact if you try to 'browse' the
avaliable
> projects in the 'Run' dialogue box the project created via cvs does not
even
> appear in the list (as though Eclipse does not even recognise it as a
> project)!
> All this boils down to the fact that I can not seem to be able to run any
of
> my code via Eclipse when it resides in one of these 'checked out' projects
> but I can if I manualy create a project and just point it's source files
to
> my sandbox.
> Can anyone shed any light on what is happening and where I might be going
> wrong.
> Many Thanks
> Tim
FUDForum. Page generated in 0.05534 seconds
