Re: Version 2.1.1 vs 3.0 [message #151159 is a reply to message #151150] |
Wed, 29 October 2003 18:19 |
Originally posted by: jgangemi.yahoo.com
have you read the "new and noteworthy" pages on the 3.0 download site?
http://download2.eclipse.org/downloads/drops/S-3.0M4-2003101 01454/eclipse-news-M4.html
(you can also view the past milestone changes from that page as well).
those detail major changes and from there you'll see a lot has changed
between the two versions.
-jae
On Wed, 29 Oct 2003 10:03:54 -0800, "Mark" <mailtomark@gmx.net> wrote:
>Hi,
>I had some problems with the CVS-module of version 3.0 and switched back to
>2.1.1 hoping this would fix it.
>Turned out it didn't and the problem was somewhere else, but while I was
>using 2.1.1 I could not really see any difference between the two versions.
>I started out on 3.0 and then went back to 2.1.1 only briefly, but the most
>obvious things like the GUI, settings and most functions I used during this
>short time all seemed to be the same.
>What has really changed between 2.1.1 and 3.0? Since this sounds like a
>major version change, I expected more drastic changes.
>The second question: How stable is version 3 - especially the "3.0 Stream
>Stable Build". It seemed to me like it's might even be ready for
>production!?
>Thanks,
>MARK
FUDForum. Page generated in 0.02509 seconds
