Re: Is any formatters available? [message #151050 is a reply to message #151038] |
Thu, 11 August 2005 09:45 |
Originally posted by: ude.npn-gmbh.de
"Alexey Kakunin" <akakunin@emdev.ru> wrote
> I want to Format a big set of code - actually I need to reformat it into
> Unix-style. But in CDT settings on Formatters page I have (NONE) in
> combobox. Are any formatters (somethere) available for CDT?
Somebody wrote a very basic formatter using indent which is part of linux
and cygwin too. If I remember right that was announced in this group. Take a
look back. Otherwise try to google [eclipse plugin indend] or similar for
example.
> I'm using Eclipse 3.1 & CDT 2.1.1
Does this work? I've read that CDT 3.0 is required for use with eclipse 3.1.
That's also my configuration.
Hans
Re: Is any formatters available? [message #151081 is a reply to message #151058] |
Fri, 12 August 2005 14:09 |
Originally posted by: plankton.softwitch.net
Sorry for your trouble. I am the author of simple indent. SI is my first
eclise plugin for practice.
In my guessing, If you using lower version than java 5.0, That strange
message will be appear. (SI doesn't use osgi platform, so that error
message is somehow strange)
Anyway, That problem is now fixed with SI 1.0.6. (Compability patch for
java 1.2, 1.3, 1.4)
SI2.0 will be announced here within 1 month. It has own parser,
Indentation Model, Source Printer. Ant It supports All C/C++ spec and
Coding rule in Pure java)
Alexey Kakunin wrote:
> Hans-J. Ude wrote:
>> I've just found back the link.
>> http://softwitch.net/blog/index.php/simple-indent-code-forma tter-for-cdt/
> Thank, downloaded, installed, but unfortunatelly I cannot see preference
> page, it give me error "Plugin org.eclipse.cdt.simpleIndent was unable
> to load class
> org.eclipse.cdt.simpleIndent.preferences.SimpleIndentPrefere ncePage "
> IN log I found message: "org.osgi.framework.BundleException: The
> activator org.eclipse.cdt.simpleIndent.SimpleIndentPlugin for bundle
> org.eclipse.cdt.simpleIndent is invalid" with huge stack trace.
> On the simpleIndent site I found message with same problem but without
> solution.
> Since I'm really is not very experience in Eclipse internal I cannot
> solve this problem by myself.
> Did anybody already met and solved this problem?
Re: Is any formatters available? [message #154919 is a reply to message #151081] |
Wed, 21 September 2005 22:45 |
I was wondering if there is any update on the progress on SI2.0. It
sounds great and something CDT really needs!
thanks,
adam
> java 1.2, 1.3, 1.4)
>> preference page, it give me error "Plugin org.eclipse.cdt.simpleIndent
>> was unable to load class
>> solution.
FUDForum. Page generated in 0.04112 seconds
