Home » Language IDEs » Java Development Tools (JDT) » Debugging Inner Class on M7
Debugging Inner Class on M7 [message #150223] Tue, 23 March 2004 08:55 Go to next message
Originally posted by: l.forni.inwind.it
I noticed a problem when i debug an RCP (any app) with eclipse M7
I have to rebuild the project and restart it if i want to see any
modification in source code of an inner class.
Hot code replacement works well in debug on a normal java class.
Anyone has noticed the same behaviour?
Thanx
Re: Debugging Inner Class on M7 [message #150239 is a reply to message #150223] Tue, 23 March 2004 11:33 Go to previous messageGo to next message
This is a limitation of the hot code replacement of the VM that you are
using.
Talk to you VM provider.
Darins
"Luca Forni" <l.forni@inwind.it> wrote in message
news:c3pfc1$mfj$1@eclipse.org...
> Thanx
Re: Debugging Inner Class on M7 [message #150261 is a reply to message #150223] Tue, 23 March 2004 12:59 Go to previous messageGo to next message
Luca,
M7, XP, 1.4.2_04 I'm not have the same problems. Hot swap works fine if
you don't change the method signature of ANY method in the class.
If that's not what you are seeing, carefully read the failure dialog.
If the vm rejected the change, the issue is in your VM not eclipse.
> Thanx
Re: Debugging Inner Class on M7 [message #150286 is a reply to message #150261] Wed, 24 March 2004 05:49 Go to previous messageGo to next message
I've made the same debug in eclipse 2.1.1 and eclipse M7 with the same vm
(1.4.2_03).
When i make a change in source code of an inner class, eclipse 2.1.1 works
well, but M7 doesn't take the changes.
So i think it is an eclipse problem.
"exquisitus" <user@domain.invalid> ha scritto nel messaggio
news:c3ptms$a8v$1@eclipse.org...
> Luca,
> > Thanx
Re: Debugging Inner Class on M7 [message #150310 is a reply to message #150286] Wed, 24 March 2004 08:25 Go to previous messageGo to next message
Log a bug report with a reproducible test case against JDT Debug
Darins
news:c3roqr$cei$3@eclipse.org...
> (1.4.2_03).
> > Luca,
> > > Thanx
Re: Debugging Inner Class on M7 [message #150389 is a reply to message #150310] Wed, 24 March 2004 11:02 Go to previous messageGo to next message
I made some test to have a simple test case, but i found that hotcode
replacement works well debugging simple inner class.
But i noticed that sometimes eclipse doesn't make build on changed resourced
debugging inner class in my application .
Infact if i press CTRL+b during debug, hotcode replacement works.
I'm sorry but i don't know how to make a reproducible test case because i
don't understand what the cause is.
Thanx anyway.
"Darin Swanson" <Darin_Swanson@us.ibm.com> ha scritto nel messaggio
news:c3s1m7$mt9$1@eclipse.org...
> Darins
> > Hi,
vm
> > (1.4.2_03).
works
> > > Luca,
if
> > > > Thanx
Re: Debugging Inner Class on M7 [message #150397 is a reply to message #150389] Wed, 24 March 2004 11:13 Go to previous messageGo to next message
If you have turned off "Perform build automatically on resource
modification" no build will occur when a resource is changed.
Ctrl-B is enabled when "Perform build automatically on resource
modification" (autobuild) is turned off.
HTH
Darins
news:c3sb6f$43p$1@eclipse.org...
resourced
> Thanx anyway.
> > Darins
> > > Hi,
> vm
> > > (1.4.2_03).
> works
> > > > Luca,
fine
> if
dialog.
> > > > > Thanx
Re: Debugging Inner Class on M7 [message #150436 is a reply to message #150397] Wed, 24 March 2004 12:14 Go to previous message
When i made tests i had "Perform build automatically on resource
modification" turned on.
Infact hotcode replacement mostly works except for this strange behavior
with inner class in my big project.
Luca
news:c3sbha$4je$1@eclipse.org...
> HTH
> Darins
> resourced
i
> > Thanx anyway.
> > > Darins
> > > > Hi,
same
> > vm
> > > > (1.4.2_03).
> > works
> > > > > Luca,
> fine
> > if
> dialog.
eclipse.
M7
any
> > > > > > Thanx
Previous Topic:Code sections collapse
Next Topic:Ant external build "Rebuild All" odd behaivor.
Current Time: Sun Oct 26 16:00:49 EDT 2025
Powered by FUDForum. Page generated in 0.04891 seconds
