Home » Language IDEs » C / C++ IDE (CDT) » Strange behavior of the console
Strange behavior of the console [message #149578] |
Wed, 20 July 2005 07:20 |
Originally posted by: jonkersbart.gmail.com
Hey,
I uses Eclipse 3.1 and build I200507180855 of CDT on a linux system in
combination with the GNU toolchain.
The program:
#include <stdio.h>
int add(int a, int b;
int main(int argc, char *argv[])
int int1, int2, res;
printf("Give the first integer: \n");
scanf("%d%*c", &int1);
printf("Give the second integer: \n");
scanf("%d%*c", &int2);
res = add(int1, int2);
printf("Result: %d\n",res);
return 0;
int add(int a, int b)
return a + b;
When I run the program, the first printf didn't appear at the console.
When I enter an integer I get the first and second printf at the screen.
After execution of the program the console looks like this:
4
7
Result: 11
When I debug the program or execute it at a prompt the program run as
expected and show the first printf.
Has somebody an idea to solve this problem?
Is this a bug?
Bart
Re: Strange behavior of the console [message #149620 is a reply to message #149578] |
Wed, 20 July 2005 11:19 |
Originally posted by: j_apter.hotmail.com
Hmm, I was going to suggest that you might be seeing this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=102043
(Bug 102043 - Console Output Does Not Appear When Launching An
Application). However, your test case is a bit different than mine (I
also haven't tested the problem on linux yet).
Go to your workspace/.metadata directory and tell me if you see any
exceptions thrown in the .log file. I'd imagine that if you do see some
IOExceptions they may have a different error message since the "The handle
is invalid" message that appears in the mentioned bug is a Win32 API error
message.
Let me know if any of this seems to be related to your issue.
Bart Jonkers wrote:
> Hey,
> The program:
> #include <stdio.h>
> printf("Give the first integer: n");
> printf("Give the second integer: n");
> printf("Result: %dn",res);
> return 0;
> return a + b;
> 4
> 7
> Result: 11
> Is this a bug?
> Bart
Re: Strange behavior of the console [message #149629 is a reply to message #149620] |
Wed, 20 July 2005 11:55 |
> handle is invalid" message that appears in the mentioned bug is a Win32
> API error message.
Yes there are some exceptions when I run the program:
!ENTRY org.eclipse.debug.core 4 120 2005-07-20 13:33:07.279
!MESSAGE Error logged from Debug Core:
!STACK 0
java.io.IOException: read error
at org.eclipse.cdt.utils.spawner.SpawnerInputStream.read0(Nativ e Method)
org.eclipse.cdt.utils.spawner.SpawnerInputStream.read(Spawne rInputStream.java:60)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at java.io.FilterInputStream.read(Unknown Source)
org.eclipse.debug.internal.core.OutputStreamMonitor.read(Out putStreamMonitor.java:137)
org.eclipse.debug.internal.core.OutputStreamMonitor.access$1 (OutputStreamMonitor.java:127)
org.eclipse.debug.internal.core.OutputStreamMonitor$1.run(Ou tputStreamMonitor.java:193)
at java.lang.Thread.run(Unknown Source)
!ENTRY org.eclipse.debug.core 4 120 2005-07-20 13:33:07.280
!STACK 0
java.io.IOException: close error
org.eclipse.cdt.utils.spawner.SpawnerOutputStream.close(Spaw nerOutputStream.java:68)
org.eclipse.debug.internal.core.InputStreamMonitor.write(Inp utStreamMonitor.java:109)
org.eclipse.debug.internal.core.InputStreamMonitor$1.run(Inp utStreamMonitor.java:80)
When I comment out the lines with the scanf function, the output appears
correctly.
Bart
> Bart Jonkers wrote:
>> Hey,
>> The program:
>> #include <stdio.h>
>> return 0;
>> return a + b;
>> screen. After execution of the program the console looks like this:
>> 4
>> 7
>> Result: 11
>> Is this a bug?
>> Bart
Re: Strange behavior of the console [message #149669 is a reply to message #149629] |
Wed, 20 July 2005 23:15 |
Yea, that seems to be the same bug. It appears as though the Eclipse guys
changed the way applications get launched. I believe a change was made in
the Eclipse 3.1RC2 release where they create a new thread to run the
launched application. This creates problems with the CDT launcher as
there is now a race condition between the actual running application and
CDT's console trying to capture the I/O (i.e. the application outputs the
printf before the other thread that captures the I/O can read from the
output descriptor). Most of this is just theory since I haven't had the
time to do a real debug on the problem, but I have a strong feeling that
simply synchronize'ing a method/block of code in a couple of places could
fix this. I mention this because the developers don't seem to be noticing
the issue so I'm trying to find someone with a bit more time than myself
to look into it (not to mention that few other people on this newsgroup
seem to notice it either). :)
In the meantime, I suggest going back to Eclipse 3.1RC1 which doesn't
exhibit this behavior. I am anxious to fix this bug so that I can use all
of the other latest plugins without having to run two copies of Eclipse.
>> API error message.
> !STACK 0
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> correctly.
> Bart
>> Bart Jonkers wrote:
>>> Hey,
>>> The program:
>>> #include <stdio.h>
>>> return 0;
>>> return a + b;
>>> 4
>>> 7
>>> Result: 11
>>> Is this a bug?
>>> Bart
Current Time: Sat Jul 27 16:21:14 GMT 2024
Powered by FUDForum. Page generated in 0.03396 seconds
