Re: WTP1.0M9 - Deploy to JBoss [message #149540 is a reply to message #149437] |
Mon, 28 November 2005 14:59 |
Originally posted by: david.schneider.unisys.com
Plus the Jboss server definition file that I had for M8 no longer works for
M9.
"Antonio Gurisatti" <maguri@epm.net.co> wrote in message
news:0714584a93d12aac734397853722a3cb$1@www.eclipse.org...
>I built the tutorials "Building and Running a Web Application" and
>"Building a School Schedule Web Application" depolying them in Tomcat 5.5
>easily.
> Then I tried to deploy them to JBoss 3.2.3 (The only JBoss server
> configurable by WTP1.0M9) and simply could'nt.
> Then I tried to start over and build them from zero and could'nt.
> There is'nt even a way to select JBoss 3.2.3 as a Target Runtime Server.
> When you create a new "Dynamic Web Project", the "Target runtime:" drop
> list does not show JBoss. Even more, it does'nt show up as an option in
> any WEB application types.
> I'm sure I've installed correctly the JBoss3.2.3 Runtime Environment in
> Eclipses preferences. I've even created a server using it and it starts
> and closes with no errors but there is no way to add a project to it.
> So, what can I do?
> As a matter of fact, why WTP is still using JBoss 3.2.3 if it's more or
> less 2 years old? (I had to download it because I'm using version 4.0.2
> some months ago and 3.2.3 went to paper basket!).
FUDForum. Page generated in 0.02607 seconds
