Home » Archived » BIRT » Parameters don't work in framset format
Parameters don't work in framset format [message #149271] Wed, 29 March 2006 14:29 Go to next message
Carlos Dias is currently offline Carlos DiasFriend
I'm trying to pass parameters to my report throw the HTTPRequest.
In the run view work fine, but in the framset view this user parameters
are not set.
http://localhost:8080/birt-viewer/run?__report=Report\myrepo rt.rptdesign&myParam1=20060311
(this works in "run").
I'm using the viewer version 2.0.1.
Carlos Dias
Re: Parameters don't work in framset format [message #149300 is a reply to message #149271] Wed, 29 March 2006 14:09 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Carlos,
This has been reported as a bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=129089
One way to get around it is to
specify a report document name
http://localhost:8080/birt-viewer/frameset?__report=Report/m yreport.rptdesign&__document=Report/test.rptdocument& ;__overwrite=true&myParam1=20060311
I put the overite in so it will delete the file everytime you call it.
Jason
"Carlos Dias" <cdias@pontoc.pt> wrote in message
news:e0e5jv$s1o$1@utils.eclipse.org...
> are not set.
> Carlos Dias
Re: Parameters don't work in framset format [message #149689 is a reply to message #149300] Thu, 30 March 2006 18:43 Go to previous message
Thanks for the answer Jason.
I try without the "__document=Report/test.rptdocument" and works fine too.
Carlos Dias
Jason Weathersby wrote:
> Carlos,
> Jason
>> are not set.
>> Carlos Dias
Previous Topic:Embeding multiple logics in a single Report Design
Next Topic:MDX Support in BIRT
Current Time: Sat Nov 09 03:05:13 GMT 2024
Powered by FUDForum. Page generated in 0.02592 seconds
