Property View - Always Alphabetical [message #149219] |
Fri, 24 October 2003 20:45 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: brian.fernandes.codito.com
I'm writing a pluigin using GEF. My Model objects implement
IPropertySource... I can see the properties in the property view when I
select an EditPart.
The problem is, the Categories are always displayed in alphabetical order;
and within the Categories as well, all the Properites are dispalyed in
alphabetical order.
I've noticed this while selecting a file in the Navigation view as well; the
file properties are displayed alphabetically.
Is there anyway I can specify the order ... ideally I would like for the
properties to be dispalyed in the order in which I specify them in the
propertyDescriptor Array.
Perhaps this an option somewhere... but I couldn't find anything in the
properties view or in the preferences.
Brian.
Re: Property View - Always Alphabetical [message #149252 is a reply to message #149219] |
Fri, 24 October 2003 21:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: John_Arthorne.oti.com_
Please see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=1883
Feel free to add your vote to the bug if this is important to you.
> select an EditPart.
> alphabetical order.
> Brian.
FUDForum. Page generated in 0.03060 seconds
