Home » Modeling » GMF (Graphical Modeling Framework) » Get the EditPart from the Model
Get the EditPart from the Model [message #149159] Thu, 06 September 2007 03:22 Go to next message
Hi all,
I am trying to create my own OutlineView for my GMF project.
I have succeded in showing the elements in the outline View along with the
icons and labels.
My problem is when i click on any of the element in the tree viewer it
does not select the same element on my canvas.Rather it always selects the
root.
While debugging i found out that following code is present in the class
AbstractEditPart :-
protected void refreshChildren() {
Map modelToEditPart = new HashMap();
List children = getChildren();
for (i = 0; i < children.size(); i++) {
editPart = (EditPart)children.get(i);
modelToEditPart.put(editPart.getModel(), editPart);
List modelObjects = getModelChildren();
for (i = 0; i < modelObjects.size(); i++) {
model = modelObjects.get(i);
if (i < children.size()
&& ((EditPart) children.get(i)).getModel() == model)
continue;
//Look to see if the EditPart is already around but in the wrong location
editPart = (EditPart)modelToEditPart.get(model);
if (editPart != null)
reorderChild (editPart, i);
else {
//An editpart for this model doesn't exist yet. Create and insert one.
editPart = createChild(model);
addChild(editPart, i);
List trash = new ArrayList();
for (; i < children.size(); i++)
trash.add(children.get(i));
for (i = 0; i < trash.size(); i++) {
EditPart ep = (EditPart)trash.get(i);
removeChild(ep);
Re: Get the EditPart from the Model [message #149406 is a reply to message #149159] Thu, 06 September 2007 07:19 Go to previous message
Hi Arpit,
Take a look at class org.eclipse.gef.ui.parts.SelectionSynchronizer.
Boris
Arpit wrote:
> Hi all,
> the icons and labels.
> the root.
> AbstractEditPart :-
> continue;
> location
> else {
> insert one.
> removeChild(ep);
Previous Topic:Compartment and Generalization
Next Topic:export: Deployable plug-ins and fragments fails to create correct jar
Current Time: Mon Oct 27 15:25:14 EDT 2025
Powered by FUDForum. Page generated in 0.05192 seconds
