Eclipse on Debian [message #148551] |
Wed, 12 April 2006 15:06  |
Originally posted by: rene.a.vergara.gmail.com
I downloaded the package and ran the executable. I got an error message
that produced the following log:
!SESSION 2006-04-12 14:00:05.814
eclipse.buildId=M20060118-1600
java.fullversion=GNU libgcj 3.3.5 (Debian 1:3.3.5-13)
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 2006-04-12 14:00:09.751
!MESSAGE Startup error
!STACK 1
java.lang.NoSuchMethodError: method java.io.FileOutputStream.<init> was
not found.
at _Jv_ResolvePoolEntry(java.lang.Class, int) (/usr/lib/libgcj.so.4.0.0)
at org.eclipse.core.runtime.internal.adaptor.Locker_JavaNio.loc k()
(Unknown Source)
at org.eclipse.core.runtime.adaptor.FileManager.lock(boolean) (Unknown
Source)
at org.eclipse.core.runtime.adaptor.FileManager.open(boolean) (Unknown
Source)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.initFileMana ger(java.io.File,
java.lang.String, boolean) (Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.initialize(o rg.eclipse.osgi.framework.adaptor.EventPublisher)
(Unknown Source)
org.eclipse.osgi.framework.internal.core.Framework.initializ e(org.eclipse.osgi.framework.adaptor.FrameworkAdaptor)
(Unknown Source)
org.eclipse.osgi.framework.internal.core.Framework.Framework (org.eclipse.osgi.framework.adaptor.FrameworkAdaptor)
(Unknown Source)
org.eclipse.osgi.framework.internal.core.OSGi.createFramewor k(org.eclipse.osgi.framework.adaptor.FrameworkAdaptor)
(Unknown Source)
org.eclipse.osgi.framework.internal.core.OSGi.OSGi(org.eclip se.osgi.framework.adaptor.FrameworkAdaptor)
(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(java .lang.String[],
java.lang.Runnable) (Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[],
at _Jv_CallAnyMethodA(java.lang.Object, java.lang.Class, _Jv_Method,
boolean, java.lang.Class[], jvalue, jvalue) (/usr/lib/libgcj.so.4.0.0)
boolean, java.lang.Class[], java.lang.Object[]) (/usr/lib/libgcj.so.4.0.0)
at java.lang.reflect.Method.invoke(java.lang.Object,
at org.eclipse.core.launcher.Main.invokeFramework(java.lang.Str ing[],
java.net.URL[]) (Unknown Source)
at org.eclipse.core.launcher.Main.basicRun(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.run(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.main(java.lang.String[]) (Unknown
Source)
!SESSION Wed Apr 12 14:00:09 GMT+00:00 2006
!ENTRY org.eclipse.core.launcher 4 0 2006-04-12 14:00:09.865
!MESSAGE Exception launching the Eclipse Platform:
!STACK
Source)
Source)
at gnu.gcj.runtime.FirstThread.call_main() (/usr/lib/libgcj.so.4.0.0)
at gnu.gcj.runtime.FirstThread.run() (/usr/lib/libgcj.so.4.0.0)
at _Jv_ThreadRun(java.lang.Thread) (/usr/lib/libgcj.so.4.0.0)
at _Jv_RunMain(java.lang.Class, byte const, int, byte const, boolean)
at __gcj_personality_v0 (osgi)
at __libc_start_main (/lib/tls/libc-2.3.2.so)
at _Jv_RegisterClasses (osgi)
Any sugestions on what could be the problem?
Re: Eclipse on Debian [message #148578 is a reply to message #148551] |
Wed, 12 April 2006 17:24  |
Make sure you download a JVM (JRE or JDK, depending on what you want to
do; Sun or IBM or something else) and use it instead of relying on the
default gcj that came with your Linux system.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
FUDForum. Page generated in 0.05104 seconds
