Home » Modeling » GMF (Graphical Modeling Framework) » Label Missing after GMF 2.0 Upgrade
Label Missing after GMF 2.0 Upgrade [message #148388] Wed, 29 August 2007 15:49 Go to next message
Robert Moloney is currently offline Robert MoloneyFriend
I have a model which consists of:
A external node label.
Attached to the top of a Node.
Inside of a ContainerCompartment
After I updated the code to GMF2.0 the external node label was no longer
visible.
Any suggestions of how to fix this?
Cheers
Rob
Re: Label Missing after GMF 2.0 Upgrade [message #149829 is a reply to message #148388] Mon, 10 September 2007 16:49 Go to previous messageGo to next message
Alexander Shatalin is currently offline Alexander ShatalinFriend
Hello Robert,
Probably you can file a request for it with the model files (including .ecore
and .genmodel) attached.
Alex Shatalin
Re: Label Missing after GMF 2.0 Upgrade [message #149836 is a reply to message #149829] Mon, 10 September 2007 16:50 Go to previous messageGo to next message
Hello Alex,
> .ecore and .genmodel) attached.
In addition can you please keep the model as simple as it possible? (to let
us focus on the problem itself).
Alex Shatalin
Re: Label Missing after GMF 2.0 Upgrade [message #149859 is a reply to message #149836] Mon, 10 September 2007 17:30 Go to previous message
Nicolai Kamenzky is currently offline Nicolai KamenzkyFriend
Member
Hi Robert and Alex,
I think, I stumbled upon a similar problem when I migrated my model
files. It was caused by the loss of the values of the attributes
"Edit Pattern" and "View Pattern" of all label mappings in
gmfmap.Maybe Robert's problem is related to the value losses.
Nicolai
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Previous Topic:Problem trying to create general link types
Next Topic:Palette: how can I disable Note
Current Time: Sun Dec 22 06:32:56 GMT 2024
Powered by FUDForum. Page generated in 0.03389 seconds
