| Re: How to lunch Eclipse programmatically (from Java app.) [message #149148 is a reply to message #148989] |
Fri, 24 October 2003 13:09  |
Originally posted by: John_Arthorne.oti.com_
Try launching from within a debugger to see what's happening. Perhaps
an exception is being thrown.
mcBear wrote:
> Hi, John again
> I have got a new trouble. I created class:
> -- cut --
> import org.eclipse.core.launcher.Main;
> class qqq {
> public static void main( String[] argv ) {
> Main.main( "-os linux -ws gtk" );
> -- end cut --
> after then I compiled it I tried to run it using command:
> java -classpath "<eclipse>/org.eclipse.platform/startup.jar:." qqq
> I got nothing. Eclipse doesn't start. What am I doing wrong?! Could you
> correct me, please? If you can
> Regards
> McBear
> John Arthorne wrote:
>>Not sure if you're asking how to programatically launch eclipse from
>>within eclipse, or from a shell script or other application. The entry
>>point is org.eclipse.core.launcher.Main in startup.jar. Use the same
>>parameters that you would pass to the eclipse executable (of course -vm
>>parameter is not needed). If it is the first invocation on a given
>>-data location, it will exit after completing the install and you will
>>have to launch a second time.
>>mcBear wrote:
>>>Hi, all
>>>Dummy question but could you help me please. Which Main class method I
>>>should invoke and with which params?
>>>Regards
>>>McBear
FUDForum. Page generated in 0.03650 seconds
