What's building secret of Eclipse [message #148371] |
Fri, 12 March 2004 19:23 |
Originally posted by: mfan.simplicti.com
I used to work on java project with gvim combined ant. I write a
customized build.xml to control cimpiling. Now I switched to eclipse.jdt.
However, I cannot find the point where I can import my original build.xml
into the project for building. How can I build the my project in eclipse
with my original build.xml? Thank you.
Re: What's building secret of Eclipse [message #148607 is a reply to message #148451] |
Mon, 15 March 2004 03:23 |
Hmm. I created a new builder using ant. Now when I "Rebuild the project",
this builder is invoked. However, I found that in the tasks view, the
display of "tasks" page and the "console" page is inconsistent. Looks like
"console" page dislayed the ant-builder result, while the "tasks"
displayed the default builder result. Can I also force the "tasks" page
reflects the ant-builder result? Thank you.
Darin Swanson wrote:
> You will need to create a builder for your project that will trigger an Ant
> build using your build.xml (and likely disable the Java builder).
> See the Properties dialog for your project.
> The Builders tab is where you want to work
> HTH
> Darins
> "Max" <mfan@simplicti.com> wrote in message news:c2t2n1$tvi$1@eclipse.org...
FUDForum. Page generated in 0.02998 seconds
