No Tables etc under Schema, using jTDS driver with MS SQL Server [message #13820] |
Thu, 11 May 2006 09:47  |
Originally posted by: neil.integility.com
I'm using the jTDS driver (jtds.sourceforge.net) to connect to a MS SQL
Server database.
I am able to connect to the database, but I don't see anything in the
Explorer tree below the Schema level. There are no tables, views, sprocs
etc. Any ideas?
Neil
Re: No Tables etc under Schema, using jTDS driver with MS SQL Server [message #13836 is a reply to message #13820] |
Thu, 11 May 2006 10:43  |
Sorry, I didn't notice that there was a corresponding stack trace in the
Error Log. Here it is:
org.eclipse.datatools.connectivity.sqm.internal.core.definit ion.DatabaseDefinitionImpl.supportsSequence(DatabaseDefiniti onImpl.java:956)
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.vnode.ServerExplorerVNodeCon tentProviderNav.displaySchemaChildren(ServerExplorerVNodeCon tentProviderNav.java:105)
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.AbstractOnDemandContentProvi derNav.getChildren(AbstractOnDemandContentProviderNav.java:1 21)
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.AbstractOnDemandContentProvi derNav.getChildren(AbstractOnDemandContentProviderNav.java:2 28)
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.AbstractLayoutProviderNav.ge tChildren(AbstractLayoutProviderNav.java:88)
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.impl.ServerExplorerContentProviderN av.getChildren(ServerExplorerContentProviderNav.java:213)
org.eclipse.datatools.connectivity.ui.CommonContentProviderB ase.getChildren(CommonContentProviderBase.java:175)
org.eclipse.ui.internal.navigator.extensions.SafeDelegateTre eContentProvider.getChildren(SafeDelegateTreeContentProvider .java:73)
org.eclipse.ui.internal.navigator.extensions.SafeDelegateTre eContentProvider.getChildren(SafeDelegateTreeContentProvider .java:250)
org.eclipse.ui.internal.navigator.extensions.SafeDelegateTre eContentProvider.getChildren(SafeDelegateTreeContentProvider .java:71)
org.eclipse.ui.internal.navigator.NavigatorContentServiceCon tentProvider.internalGetChildren(NavigatorContentServiceCont entProvider.java:243)
org.eclipse.ui.internal.navigator.NavigatorContentServiceCon tentProvider.getChildren(NavigatorContentServiceContentProvi der.java:600)
org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:1145)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeView er.java:748)
org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChil dren(AbstractTreeViewer.java:559)
org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildr en(AbstractTreeViewer.java:528)
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:711)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:690)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:872)
org.eclipse.jface.viewers.AbstractTreeViewer.internalExpandT oLevel(AbstractTreeViewer.java:1480)
org.eclipse.jface.viewers.AbstractTreeViewer.internalExpandT oLevel(AbstractTreeViewer.java:1490)
org.eclipse.jface.viewers.AbstractTreeViewer.expandToLevel(A bstractTreeViewer.java:871)
org.eclipse.jface.viewers.AbstractTreeViewer.expandToLevel(A bstractTreeViewer.java:854)
org.eclipse.jface.viewers.AbstractTreeViewer.expandAll(Abstr actTreeViewer.java:843)
org.eclipse.datatools.connectivity.ui.dse.actions.ExpandAllA ctionDelegate.run(ExpandAllActionDelegate.java:51)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:441)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: No Tables etc under Schema, using jTDS driver with MS SQL Server [message #574841 is a reply to message #13820] |
FUDForum. Page generated in 0.03310 seconds
