Home » Language IDEs » ServerTools (WTP) » using jstl taglibs
using jstl taglibs [message #148221] Tue, 22 November 2005 07:30 Go to next message
I just started working with jsp for the first time. I tried using it with
jstl, but I got some errors. I put the 2 jar files that come with the jstl
in WEB-INF/lib . I then added "<%@taglib
uri="http://java.sun.com/jsp/jstl/xml" prefix="x"%> to my jsp file. When
trying to access this jsp I got:
[Fatal Error] jstl::1:1: Content is not allowed in prolog.
ERROR: 'Content is not allowed in prolog.'
FATAL ERROR: 'Could not compile stylesheet'
Any idea why?
Zohar.
Re: using jstl taglibs [message #148229 is a reply to message #148221] Tue, 22 November 2005 10:49 Go to previous messageGo to next message
> Any idea why?
Where and when was this error reported?
- Nitin
Re: using jstl taglibs [message #148353 is a reply to message #148221] Tue, 22 November 2005 12:18 Go to previous messageGo to next message
Originally posted by: erickson_d.yahoo.removethis.com
I can't say for sure if this is your problem, but there are some
versions of JSTL kicking around that have bad TLDs. I had trouble with
a version that I got from an older JWSDP. But I'm using a version out
of the Apache Tomcat 5.5 distribution that works fine.
Zohar wrote:
> Any idea why?
> Zohar.
Re: using jstl taglibs [message #148434 is a reply to message #148229] Wed, 23 November 2005 02:11 Go to previous messageGo to next message
In the console, when I try getting this jsp with a firefox browser. It's
also displayed as the result of the GET action.
"Nitin Dahyabhai" <nitind@us.ibm.com> wrote in message
news:dlvemd$6qs$1@news.eclipse.org...
>> jstl in WEB-INF/lib . I then added "<%@taglib
>> Any idea why?
> - Nitin
Re: using jstl taglibs [message #148441 is a reply to message #148353] Wed, 23 November 2005 02:12 Go to previous messageGo to next message
What do I have to do with those TLD files? Sorry if this sounds stupid...
"Doug Erickson" <erickson_d@yahoo.removethis.com> wrote in message
news:dlvjt1$f8b$1@news.eclipse.org...
>I can't say for sure if this is your problem, but there are some versions
>of JSTL kicking around that have bad TLDs. I had trouble with a version
>that I got from an older JWSDP. But I'm using a version out of the Apache
> Zohar wrote:
>> Any idea why?
>> Thanks,
>> Zohar.
Re: using jstl taglibs [message #148501 is a reply to message #148434] Wed, 23 November 2005 09:09 Go to previous messageGo to next message
Could you post the first rows of your jsp?
Perhaps your applications server does not compile it and sends it directly
to the browser.
You should not have something like
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/strict.dtd"> in your jsp.
Andreas
Re: using jstl taglibs [message #148527 is a reply to message #148501] Wed, 23 November 2005 10:32 Go to previous messageGo to next message
<%@ page language="java" contentType="text/html; charset=ISO-8859-1"
pageEncoding="ISO-8859-1"%>
<%@taglib uri="http://java.sun.com/jsp/jstl/core" prefix="c"%>
<%@taglib uri="http://java.sun.com/jsp/jstl/xml" prefix="x"%>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<title>MY PAGE</title>
</head>
<body>
HELLO THERE
</body>
</html>
"Andreas Holtz" <A.Holtz@gmx.net> wrote in message
news:85e544de8f836c9d41631bfc150f9a89$1@www.eclipse.org...
> to the browser.
> Andreas
Re: using jstl taglibs [message #148565 is a reply to message #148501] Wed, 23 November 2005 12:11 Go to previous messageGo to next message
it seems that this line is the problematic one:
when I take it out the page compiles fine.
> to the browser.
> Andreas
Re: using jstl taglibs [message #148581 is a reply to message #148565] Wed, 23 November 2005 12:28 Go to previous messageGo to next message
I believe it should be "http://java.sun.com/jstl/xml", without the
"jsp". Assuming there's no relevant taglib declaration in the web.xml,
then the TLD will be read directly from the jar's internal META-INF
directory. If you are unsure what the URI should be, examine the
appropriate TLD within the jar, x.tld in this case. Find the <uri>
element and that will give you what you should specify.
Larry
>>to the browser.
>>Andreas
Re: using jstl taglibs [message #148805 is a reply to message #148581] Thu, 24 November 2005 01:42 Go to previous messageGo to next message
I have this in x.tld:
<description>JSTL 1.1 XML library</description>
<display-name>JSTL XML</display-name>
<tlib-version>1.1</tlib-version>
<short-name>x</short-name>
<uri>http://java.sun.com/jsp/jstl/xml</uri>
So it seems like it's http://java.sun.com/jsp/jstl/xml - is that correct?
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:dm28r8$ae9$1@news.eclipse.org...
>I believe it should be "http://java.sun.com/jstl/xml", without the "jsp".
>Assuming there's no relevant taglib declaration in the web.xml, then the
>TLD will be read directly from the jar's internal META-INF directory. If
>you are unsure what the URI should be, examine the appropriate TLD within
>the jar, x.tld in this case. Find the <uri> element and that will give you
> Cheers,
> Larry
>>>directly to the browser.
>>>Andreas
Re: using jstl taglibs [message #149058 is a reply to message #148221] Thu, 24 November 2005 17:47 Go to previous messageGo to next message
Originally posted by: thisisnot.mymail.com
Zohar wrote:
> Any idea why?
> Zohar.
Do you have xalan in you libs?
Re: using jstl taglibs [message #149425 is a reply to message #149058] Sun, 27 November 2005 02:14 Go to previous messageGo to next message
no, should I?
"Srgjan Srepfler" <thisisnot@mymail.com> wrote in message
news:dm5fuc$90j$1@news.eclipse.org...
> Zohar wrote:
>> Any idea why?
>> Thanks,
>> Zohar.
Re: using jstl taglibs [message #149433 is a reply to message #148805] Sun, 27 November 2005 16:00 Go to previous messageGo to next message
I think I was looking at a jar from JSTL 1.0.x, so it looks like they
changed the URI going to 1.1. Since your URI was correct, I'm not sure
why the taglib tag was causing problems.
Larry
>>Cheers,
>>Larry
>>>>Andreas
Re: using jstl taglibs [message #149552 is a reply to message #148527] Mon, 28 November 2005 10:46 Go to previous messageGo to next message
try to remove
good luck
Andreas
Re: using jstl taglibs [message #149668 is a reply to message #149433] Tue, 29 November 2005 08:45 Go to previous messageGo to next message
I've now reduced the jsp to this:
---------------------------8<-------------------------------------------------
<x:transform xml="restaurants.xml" xslt="restaurants.xsl" />
I still get this when trying to get it:
Nov 29, 2005 3:39:48 PM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet jsp threw exception
javax.xml.transform.TransformerConfigurationException: Could not compile
stylesheet
If I take out the line
it works OK (nothing is returned, but no exception is thrown)
news:dmd6qb$rho$1@news.eclipse.org...
>changed the URI going to 1.1. Since your URI was correct, I'm not sure why
> Larry
>>>Cheers,
>>>Larry
>>>>>Andreas
Re: using jstl taglibs [message #149722 is a reply to message #149668] Tue, 29 November 2005 11:29 Go to previous messageGo to next message
> stylesheet
it looks like restaurants.xml is itself not well-formed. Perhaps
it's missing the XML declaration at the start or the DOCTYPE is invalid?
- Nitin
Re: using jstl taglibs [message #150129 is a reply to message #149722] Thu, 01 December 2005 01:59 Go to previous messageGo to next message
Here it is attached...
news:dmhvkt$cll$1@news.eclipse.org...
>> invoke
>> stylesheet
> - Nitin
Re: using jstl taglibs [message #150258 is a reply to message #150129] Thu, 01 December 2005 05:05 Go to previous messageGo to next message
>>>invoke
>>>stylesheet
My bad. It looks like it's complaining about the stylesheet.
- Nitin
Re: using jstl taglibs [message #150340 is a reply to message #150258] Thu, 01 December 2005 07:11 Go to previous messageGo to next message
here it is then...
news:dmmht3$jnd$1@news.eclipse.org...
>>>>invoke
>>>>stylesheet
> - Nitin
Re: using jstl taglibs [message #150546 is a reply to message #150340] Fri, 02 December 2005 20:23 Go to previous messageGo to next message
Did you try putting xalan or xerces?
Zohar wrote:
> here it is then...
Re: using jstl taglibs [message #150668 is a reply to message #150546] Sun, 04 December 2005 01:35 Go to previous message
put where?
news:dmqs36$f8s$1@news.eclipse.org...
> Zohar wrote:
>> here it is then...
Previous Topic:Marking editor dirtly from ServerEditorSection
Next Topic:How to combine Ant into Dynamic Web Project?
Current Time: Fri Oct 24 12:52:59 EDT 2025
Powered by FUDForum. Page generated in 0.08535 seconds
