make a node non-resizable + non-movable ? [message #148048] |
Tue, 28 August 2007 12:18 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: NOSPAM.xyz.com
I am working on an application in which a lot of useful data
is represented by the exact sizes and relative locations of the nodes.
In some cases the size + location of a node of given type must
be frozen to indicate that this node is in certain state.
How can one do that?
On that node I installed
NonResizableEditPolicyEx
and I also return null from
getDragTacker()
This helped somewhat - now that node does not get selected when
I click on it with the SelectionTool.
However, if I drag a marquee around it it is still gets selected and can
be moved + resized by using the handles.
Any tips?
Theo
Re: make a node non-resizable + non-movable ? [message #148110 is a reply to message #148051] |
Tue, 28 August 2007 17:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks for the quick reply Boris.
I just achieved something similar by overriding
public EditPolicy getPrimaryDragEditPolicy()
to return new UnmovableShapeEditPolicy();
In my case this seems a good way to go because I would like
to deny changing the colors, etc, via the prop. sheet.
Instead, the combination of fore- + background colors should indicate
the special state of this node. Sorry for missing this in my original post.
I would even like to remove the handles because they suggest
editing capabilities. Somehow they survive yet. So now
I am scrambling to find who shows the outline frame with the
handles around a selected node.
Theo
"Boris Blajer" <boris.blajer@borland.com> wrote in message
news:fb14hl$4q0$1@build.eclipse.org...
> Hi Theo,
> You may return an unexecutable command instead of SetBoundsCommand from
> the <>LayoutEditPolicy of its parent. Thus it will be possible to select
> the node (e.g., to change its properties via the property sheet), but any
> attempt to move it will fail.
> Best regards,
> Boris
>> getDragTacker()
>> Any tips?
>> Theo
Re: make a node non-resizable + non-movable ? [message #148112 is a reply to message #148110] |
Tue, 28 August 2007 17:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Boris Blajer![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=boris.blajer%40gmail.com) Messages: 217 Registered: July 2009 |
Hi Theo,
Returning false from EditPart#isSelectable() method may help you get rid
of the handles.
Boris
> Cheers,
> Theo
>> Hi Theo,
>> Best regards,
>> Boris
>>> getDragTacker()
>>> Any tips?
>>> Theo
Re: make a node non-resizable + non-movable ? [message #148114 is a reply to message #148112] |
Tue, 28 August 2007 17:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Yes it does... Today is my lucky day....
MAny thanks
Theo
news:fb1n1f$sq3$1@build.eclipse.org...
> Hi Theo,
> of the handles.
> Best regards,
> Boris
>> post.
>> Cheers,
>> Theo
>>> Hi Theo,
>>> any attempt to move it will fail.
>>> Best regards,
>>> Boris
>>>> getDragTacker()
>>>> can
>>>> Any tips?
>>>> Theo
FUDForum. Page generated in 0.03687 seconds
