| Trouble using multiple creation tools on a same node [message #148033] |
Tue, 28 August 2007 03:13  |
I try to have a diagram with several creation tools creating a same class
node with different figures.
So, I have :
- a node class named MyNode,
- two figures named MyNodeFigure1 and MyNodeFigure2
- two creation tools, Creation Tool 1 (attaching MyNodeFigure1 to a MyNode
node) and Creation Tool 2 (attaching MyNodeFigure2 to a MyNode node)
The Creation tool 2 is the second generated creation tool in the order of
appearance in the map file and it does not work...
Objects created by Creation Tool 2 don't appeared until you move (with the
mouse) an other object on the diagram. Furthermore, these objects are
created using the figure MyNodeFigure1 (corresponding to the first tool, and
not the second one).
This trouble is easily reproducible and it is really blocking for me.
Someone could help me to fix it ? I use the latest release GMF 2.0.
Fabrice Dubach
FUDForum. Page generated in 0.03674 seconds
