Home » Language IDEs » C / C++ IDE (CDT) » code template date variable format
code template date variable format [message #147972] Sun, 03 July 2005 21:24 Go to next message
Can anyone please tell me where the date format is set for use with CDT
code template variable date? I am running XP, CDT RC1. My format is
D/MM/YYYY whereas my colleague has MMM D, YYYY. My "Regional and
Language Options" has a short date D MMM YY so it's obviously not
picking up that setting - must get it from somewhere else. Any help
would be appreciated.
Patrick
Re: code template date variable format [message #639403 is a reply to message #147972] Tue, 16 November 2010 07:36 Go to previous message
I've found this solution helpful:
http://stackoverflow.com/questions/1131712/how-to-set-the-ec lipse-date-variable-format/3546519#3546519
You can fix it for your Eclipse installation when you append following lines to your eclipse.ini:
-Duser.language=de
-Duser.region=DE
Previous Topic:Hotkey for "File Search"
Next Topic:Run Tcl/Expect and elf file
Current Time: Wed Apr 16 14:20:35 EDT 2025
Powered by FUDForum. Page generated in 0.05058 seconds
