How to prevent user to drag a contained element [message #147910] |
Mon, 27 August 2007 09:44  |
I've got an container element (A) and a contained element (B). A contains B
in a flow layout. As A and B almost have the same size, when I click on A
the editor selects B. I would like to prevent the selection of B, every
click should select the container element A.
I guess it has something to do with an Edit Policy but I can't find it, any
clue ?
Cédric
Re: How to prevent user to drag a contained element [message #147959 is a reply to message #147945] |
Mon, 27 August 2007 11:12  |
Hi Cédric,
Take a look at EditPart#getTargetEditPart(),
EditPart#understandsRequest(), EditPart#performRequest(). You may also
need to delegate EditPart#showSourceFeedback(),
EditPart#showTargetFeedback() and the associated erase<>Feedback()
methods as well.
Boris
Cédric Brun wrote:
> Let's re-open the issue, now I would like the B element to be ignored by the
> tools, I'm being prevented to create connection when I hover the B
> (contained in A) but the connection is correct from an A element, and as
> the A element have no label I can't select it.
> Where do GMF find the edit part starting from the mouse position ? I could
> override this behavior no ?
> Cédric Brun wrote:
>> I found the solution myself : overriding getDragTracker in the B edit
>> part:
>> @Override
>> public DragTracker getDragTracker(Request request) {
>> return getParent().getDragTracker(request);
>> Keep up the good work !
>> Cédric
>> Cédric Brun wrote:
>>> Hi,
>>> B in a flow layout. As A and B almost have the same size, when I click on
>>> A the editor selects B. I would like to prevent the selection of B, every
>>> any clue ?
>>> Thanks,
>>> Cédric
FUDForum. Page generated in 0.03888 seconds
